Monitor warmup
Retro77
22CR
Hi all,
One of my cabs seems to be developing a fault. I had an issue a while back where the bottom of the picture was folding back up on itself. Gunblade recommended a pot tweak and this worked great. It now seems to have a separate issue.
It takes at least 5 minutes for the screen to be visible. Once it has been on for a while the picture is great but I feel like this isn't going to last. So I have opened up the back to see if I can see anything wrong.
On the photo I can see some black stuff by one quite large cap and further back there is something on top of another cap. Do you think this could be the cause of the issue? Do you think a cap kit could fix it? Or do you think that it could be something else?
Cheers all
Retro772019-10-16 14:02:45
virtvic
The Cabaret King
21 (96%)
2,012CR
The black blob is probably just hot glue to secure the cap in place. It should feel ‘rubbery’
If it’s taking a while to get going, sounds like a cap issue to me, but I’m sure the monitor boffins will chime in soon.
tb2000
3,584CR
As Vic says above that's just stuff to hold the cap in place when it's soldered originally. A monitor that takes ages for the picture to appear could be the chassis but could just as well be a tired crt. As your caps look original, I would do a cap kit on it for starters. The other cap you have circled has definitely got problems as the plastic outer has shrunk down the can due to heat, so it's almost certainly a bit dry, lost some capacitance and/or got high esr. I would also consider changing the lopt if it's an original, but the caps I would do first. I can't see what tube size it is from the pic, but if it's a 26" Zenith then you could be looking at a bad tube anyway.
neoretro
1,121CR
I had this on a track and Field. Get it looked at quickly as one day we turned the thing on got this horrible burning smell and purity of picture is completely gone.
In our case I’m almost certain it’s a tube issue. The chassis was completely serviced and we still get the burning smell and a bad picture.
In this case I’d plump for tube going bad. Is it a Wells Gardner?
tb2000
3,584CR
Your issue sounds more like a yoke problem than a tube problem. That's the only part of a crt that a smell can come from (when its got shorted windings).
neoretro
1,121CR
Yea sorry should have been clearer. I just meant not on the chassis.
TheDaddy
14 (93%)
7,230CR
Just to confirm the black stuff is just to keep it in place. It looks like its possibly been re capped at some point. If it takes 5 minutes to warm up I would think it has bad caps but I would talk to a monitor/tv repair specialist as I am only guessing.
Hope this helps,
Dave.
Retro77
22CR
Hi all,
Thanks for the replies. These are the large Superstar Deluxe cabs that were part of the rescue from the Kent raid I believe. Vic was part of the rescue party looking at the pics.
I would like to get them both back to working condtion again (the other one is fine). So, I think recapping is the first port of call. Do any of provide this service? If so, let me know and I will send you a P.M.
Now I am off to the discharging thread to teach myself how to remove the chassis.
Thanks again.
Retro77
22CR
If it is just those 2 then I will attempt it myself. I have used a soldering iron in the past for a few things. Does anyone have a preferred supplier for new caps or does it not really matter?
TheDaddy
14 (93%)
7,230CR
Just get decent ones not the rubbish off ebay. I use RS Online. I would just replace the lot personally as it wont take too long to do and if a couple are failing the rest will follow.
Dave.
