ms2933 chassis problems
geordiemick
14CR
Just recapped the nanao chassis in my blast city , this is paired with a 2930 tube.
was working ok before, except taking a while to warm up and had some color issues.
after reassembling and putting back into cab, having an issues with a rolling vertical picture, and there is no adjustment on vertical size seems small what ever I do, have tried using the factory menu but this doesnt chanhe anything.
service manual says check round u601 ic, have been over 3 times now double checking everything.
Any idea what might be resposnible for these problems ?
Ace`
PlanB contributor #1
40 (100%)
4,040CR
I'd say you must have installed a wrong value cap or installed it backwards in the sync circuit since it was working before.
geordiemick
14CR
I did get this chassis working , gave it to a friend who repaired some partially lifted pads for me , fitted it back into the cab last night , was working great super sharp image and everything .
Switched it on today to dial in the settings a bit .
Worked great for about 20 mins then just went off all of a sudden !
No static or hv
Get 110v at ac in , fuses check out fine , measured the b + reads 180 when I first switch it on then drops away to nothing .
All I’m getting is the click of the degaussing circuit , then the click off when I power it down .
Any ideas , thought I was finally finished with the issues as it was working great .
