MTC900
r-type
633CR
Hi all,
As the weather has improved I set about bringing my cabs round from their winter hibernation.
2 out of 3 have survived. The MTC900 in my Zacc cab will not power on. The only thing I've done so far was check that it was getting power from the ISO in the old italian PSU in the bottom of the cab.
It is kicking out 145v which seems too high to me. Would this prevent the monitor from starting?
Thanks all,
Andy
RaveN
1,325CR
If that's the true figure from the ISO (measured with a decent multimeter and the monitor connected), I think that's a high enough voltage to damage the monitor, let alone prevent it from starting.
r-type
633CR
Hi chaps, thank you for the replies.
Tony, it is an MTC900. I think it was the last one that Grant ever repaired. I think it sent him over the edge
It has been as good as gold for the last two years. The only thing that's happened is that I moved the cab up into our garden building as we had our garage converted for a wet room and sensory room for my disabled son.
When I measured the voltage, the iso wasn't connected to the monitor and I haven't plugged it back in since. I've got another transformer I can try I think.
tb2000
3,579CR
Ok, well then if that's the case 145v from the iso would be too much for it as the manual states maximum is 141v. There's also the possibility though that sometimes an iso will put out "more than it should" when there's no connection, so if there's something happened in the psu section that's stopping the power from getting in, it may be acting as though it's not plugged into the chassis.
r-type
633CR
Right, the other transformer measures as putting out 118v which I believe is in range looking at the manual. Still no signs of life. Fuses are all ok.
Anything else I can check?
