multimeter recommendations?
dj_yt
787CR
Honestly most cheap modern digital ones should be fine. Get one with a continuity beeper function, which I'm sure they all have.
TheDaddy
14 (93%)
7,230CR
I agree , I have fluke ones worth 100's and my £20 ones are just as good. I have a bench one I had from maplins many moons ago for £100 odd but I only spent that because I wanted it to stay on the bench ( I am forever loosing them !)
Dave.
This is one like mine - This is a pic from ebay :-
TheDaddy2020-05-30 09:57:05
aeroflott
A different league
16 (100%)
1,069CR
You'll get a lot of replies on this one, as it's really a matter of opinion. But reality is almost any multimeter will do the job. I went for a Fluke 101 after owning a cheapo one for a few years. The Flukes are well regarded, the build quality is excellent and the display is nice and big in a compact form factor. Expect to shell out around 30-50 quid depending on where you buy from. Note you'll probably have to import one as I don't think the 101 was released over here.
In short go for a Fluke if you want reliability that's going to last.
Titchgamer
123CR
I am a sparky by trade and have lots of meters.
I have Flukes worth £300 down to a £20 drapper.
And in all honesty there is not much in it for general use, If you just want to check PSU voltages and continuity dont go mad and buy something expensive just buy a well known brand digital multi.
Preferably something with auto ranging.
Just dont buy a cheapo £5 thinggy they are dangerous!
In many ways the leads are more important than the tester, Make sure you get leads that comply with GS38 and you are golden.
My personal go to is a Fluke T5 which has a built in clamp meter, Useful for me but not that handy for general use lol.
big10p
Coins detected in pocket!
6,092CR
It's funny, I started out with a cheap one, which was fine for checking voltages etc., and now I'm on my 3rd upgrade. As you get more into the hobby and learn more, you may find you need a meter with better capabilities. Current one I have is auto ranging, but the range can also be set manually, which I like. I considered a Fluke but decided I can't justify the cost. Maybe on the next upgrade.
For what it's worth, this is my current one:
https://www.amazon.co.uk/gp/product/B071JL6LLL/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Ace`
PlanB contributor #1
40 (100%)
4,040CR
I'd get a second hand fluke (and did) I had some cheap ones before that but they were just nasty. Auto range feature is very nice and a backlight for the lcd too if you're going to be in the back of cabs.
You can get a nice second hand fluke for as low as £50, just with anything the more you spend the nicer they get.
andyman
1,059CR
As many have said, not massive differences...I have 2 Flukes and 2 Uni-Ts...I use whatever is to hand with the same results
2nd hand Fluke from Feebay or a Uni T
FrancoB
17 (100%)
1,040CR
Just to echo everyone else, you don't need to spend a fortune but do avoid the £5 jobbies.
One with a continuity beep function is a must.
Another must have function IMO is one that auto powers off after a few minutes of not being used. I lost count of the amount of times I went to use my older multimeters only to find that I had left it turned on the last time I used it and the battery was flat
I'm currently using a Uni-t UT39C which does the above.
Monstermug
1,807CR
Make sure the continuity beep function is instantaneous which most cheap ones dont have. With that u can just skim the ic legs and get a beep instantly or you be holding it down on each legs and have to wait for the beep.
markjw
23CR
on the cheaper 'off-brand' multimeters be wary of the maximum ratings - I would be happy to use a Fluke or similar to test mains voltage or current draw, but would not want to try it with a cheap meter.
For low voltage use, eg in arcade machines, retro games consoles / computers a cheap meter will be fine - they won't be 100% accurate, but will be good enough.
236CR
The Aneng meters are very good for the price (all over Ebay) , wide range of them as well so just get something auto-ranging. They usually come with a bunch of different leads types as well.
Ropi Jo
127CR
As you're asking for recommendations I'd guess you're not overly familiar with multi meters (apologies if I've got this wrong).
My recommendation would be a meter with a mechanical lockout that automatically blocks the sockets that are not for the option you have selected.
For example... if you've selected 'voltage' then the 'current' socket is mechanically blocked. This stops you accidentally blowing up either the equipment or the meter.
I've had various meters over the last 40yrs from analogue AVOs to all kinds of digitals. Cheap and expensive. If you know how to use a meter properly then there is no difference between them (apart from internal resistance), but the auto blocking meters are perfect for people not too familiar with multi meters.
Mastech do a great range, including auto blocking, and there are many Mastech clones at a fraction of the price. I own originals and clones and they are great.
I hope this helps.
EDIT... just to add, I hate auto ranging. I always select the range manually. Probably just me being old fashioned (or just old).
Ropi Jo2020-05-31 19:42:46
