MV-1FZ Missing Components
funk
555CR
I received an MV-1FZ board a few weeks back, in fairness, only used it for 30 minutes to test some Metal Slug and all appeared well.
Was looking over it this afternoon and noticed a couple of bits I'm a little concerned about, I've highlighted below.
I'm going to test it again later to see if I have any issues and this has happened since, but it's been sat in a box since I last tested it and it's definitely not been given a whack since.
Worth replacing, anything to be concerned about
mourix
307CR
Seems like the missing parts are just decoupling caps. It would be best to put in some new ones, but I don't think you're gonna be in trouble playing like it is now.
mourix
307CR
Yeah that pad is gone. You'll need to scape the green solder mask off the trace and attach a wire. Or use a through hole ceramic cap that you connect to the trace directly for an easier fix.
mourix
307CR
You will need to beep them out to make sure they are connected between +5V and ground. If so, they are decoupling caps.
For decoupling the value is not critial, so 100nF gets used a lot. The voltage rating needs to be multiple times the operating voltage to not lose capacitance. So 25V or higher rated ones is what I would use.
