If I remember correctly, the Capcom unit will supply the 3.3v without the need for an additional PSU. I would imagine the MVS > JAMMA adapter will be required in all instances though, as the capcom unit will be expecting mono from the JAMMA end.
yes it'll work but you'll need to use an MVS->JAMMA adapter unless your loom has the set of plugs to swap from stereo to mono for the audio that mine has....
Capcom or Sega JAMMA->JVS will only run a Naomi-1 with carts - it doesn't output enough Amps to run a Net-Dimm.
Many thanks all, i will be powering the naomi via a naomi power supply so i can run a netdimm, i just wondered with the naomi having audio L & R it could plug into the MVS as i know this is stereo but without an mvs to jamma converter.
Yep pretty sure you could make up an adaptor for that then. Some of my adaptor fingerboards might come in useful?
The MVS wiring is speaker L + R on the jamma pins, and then a separate GND, compared to normal jamma which is Speaker + & Speaker - on the jamma pins.
You'd just need to make sure it's not used on a standard jamma cab, or it could do bad things.
