My plan to buy a Vewlix
EarthwormBen
1CR
I've been wanting to get a vewlix for a while to enjoy my shmups and fighters in a bit more style, but the only thing holding me back is that I could be moving soon.
In the mean time, I just wanted to get a few pieces of advice from people on here:
What is the best software to run, to have both your emulated and windows library run in the cleanest fashion?
Where do people recommend a purchase from (assuming nobody on here is selling, was very tempted by the Vs cab but have no room for the system atm)
Can anybody recommend any other candy cabs that are HD capable?
penrhos
747CR
Vewlix are fine for modern pc-based games but if you run a normal arcade pcb in one you'll need a decent upscaler (which introduces lag) and old games that run at low res like 320*200 look terribly blocky.
You might be better off with a Chinese clone vewlix and a decent MAME/Technoparrot PC.
https://videotronicsuk.com/arcade-machines/cabinets/chewlix-vewlix-cabinet.html
At least these are 1080P screens - the L, C & F are only 720P and my two F's were filthy and took a lot of cleaning.
EarthwormBen
1CR
I think the main concern there is the cleaning... The other areas can be worked around.
Is there a difference in quality of parts, or are they pretty much the same factory?
penrhos
747CR
I've had a Chewlix, Vewlix-L, Vewlix-F and a Diamond-black.
I won't lie the Chewlix isn't as solid as an L, C or F (metalwork and plastics are and feel a little thinner) the cab certainly weighs less, the PSU's and JVS cards are clones, mine did have a 1080P screen and a 2-player control panel and it worked fine - was 240V so no stepdown needed....
However the build quality on the diamond-black was a huge disappointment to me - so much so that I sold it - it may as well have been a Chewlix but with slightly better quality screen and stickers at three times the price...
The biggest issues with a second-hand L, C or F is the 720P screen - both of mine have brown banding caused by either burn or dirt on the backlight and to fix it you have to replace the screen or strip it down to clean the lights behind the lcd film panel - so fiddly, time consuming and potentially screen killing - I'm holding out until a decent oled 32" gaming monitor is available to swap over.
The issue with a new vewlix db is its build quality isn't as good and you get absolutely nothing inside it so no i/o boards, psu's - looms, lighting strip in control panel - nadda. so to add a JVS/Fastio pcb is around £200, then a JVS PSU and cables another £150-200, Nesica card reader £100 and it just goes on and on.
My Ideal Vewlix would be a minty C or F shell with the 1080P screen from a Diamond Black setup for JVS.
If you want no cleaning and plug-n-play get a new Chewlix for £1000.
if you want to spend a whole afternoon cleaning it and a screen you'll probably want to clean/replace at some point in the future get a JVS Vewlix C or F for £1500,
if you've for £3000-4000 to burn get a new Vewlix DB.
Ignore the Vewlix-L unless you can pick one up for < £1000 as it's pretty basic (you get marquee & instruction strip lights on the C/F, a better spec LCD and a few other extras, the F has concealed levelling feet for a start). There is a feature comparison chart on ArcadeOtaku's wiki which shows up in a google search.
https://forum.arcadeotaku.com/viewtopic.php?t=27246
penrhos2021-02-19 11:40:55
