Naomi - Atomiswave Boot Problems
trev1976
171CR
Hi
I'm having a nightmare with this , my atomiswave games don't boot 9 times out of 10 , I'm getting a error 22 code.
I've measured the volts and all seems good. I've adjusted the 3.3v from low to high but it doesn't seem to change anything.
Please help
Retro77
22CR
Hi trev1976,
Is it just Atomiswave that causes this? As Error 22 is a DIMM issue. Maybe try reseating the netDIMM.
Are you powering the Pi from the Naomi? If so, it may be worth trying to power it from a separate supply. My Naomi is very fussy about voltage
trev1976
171CR
Hi
Yes its only atomiswave , naomi games always work first time.
The PI is powered from the Sun PSU
Ill take it out and try and reseat it but yeah its a very odd system.
Retro77
22CR
Hi Trev,
It looks like this person had the same issue as yourself. At the bottom of their 1st post it looks like the problem was fixed with a BIOS swap (Japanese G)
https://www.arcade-projects.com/threads/trouble-netbooting-atomiswave-games-black-screen.1175/
I am not at home at the moment, but when I get in I will have a look what is in mine. Although I am fairly certain it is a Japanese BIOS because Virtua Tennis loads up as Power Smash.
trev1976
171CR
OH , thats some very useful information thanks , i was at my wits end with this thing so if a bios swap might work at least there is some hope for a fix
I have noticed all my games seem to be the japanese versions btw
Can anyone on here supply me with a new bios for a cost ?
Rave
3CR
There was a new multi bios posted recently on Arcade Projects that has been successfully fully decrypted to allow the native multi feature baked in by Sega finally.
It 100% cures the black screen issue and uses the latest version of the bios for naomi 1 & 2.
