Naomi Cabinet
tazfaedodge
91CR
I have now just seen the page explaining the cost of postage, I'll shut up now.
But can the mounting be removed from the back to install different joysticks?
Nick
tazfaedodge
91CR
Have now got my new Control Panel, It comes fitted (spot welded on) with mounts for the Sanwa JLF type joysticks.
I was wanting to to use the Sanwa JLW joysticks from Ultimarc.
Does anyone know if these can be fitted to this type of mount?
Nick
JohnBud
429CR
i think you will be fine, if not just get a couple of mounting plates
cosine
14 (100%)
595CR
Nick
If the joystick mount looks like this:
then a JLW will fit fine.
tazfaedodge
91CR
Ok as things are getting closer to me having everything I need to do this, I find myself asking is there a power button to switch the monitor on? or is it just the mains switch at the back of the cab?
Nick
tazfaedodge
91CR
Thanks, Have just wired my cab up plugged it in hid behind the dog and looked to see what was what.
The light flashes every now and then but the starter arcs all the time.
the box on mine says it's a 110v not 250v
Thats why I was asking.
Nick
obcd
3,830CR
Yes, the balast and starter are 110V instead of 220. It's very common for sega consoles.
Another difference people usually overlook is that the ballast is usually made for 60Hz instead of 50Hz. Due to that, the lamps die faster than they should. You can find starters for 110V in europe like the ST 151. Those where used in armatures with 2 lamps and only one ballast. Every lamp had it's own 110V starter. If one of the lamps went bad, you most of the time had to replace both of them as an old and new one didn't work well together in such a setup.
tazfaedodge
91CR
Well I have to make a trip to maplins today as I ran out of wire when I was wiring up the control panel, so will see if they have any when I'm in.
Nick
JohnBud
429CR
is it a complete cab ??? i.e. should work ??? if you get stuck i can pop round. where do you live ??? alloa. i'm in kilsyth.
tazfaedodge
91CR
Yeah It's complete to a point no game board etc as is being built as a mame system.
I have the PC in connected to the screen nice and bright but do need to fix the size, need to go into the loft and look at what I have for audio. Also finish wiring up the I-PAC2 install and configure it.
All that missing just now is the marquee light (and the speakers, they have been ordered), a marquee holder, some screws and the screw covers.
Nick
