Naomi Net dimm memory
23CR
Hi I recently bought a naomi net dimm it works great but is only 256mb when I run the dimm test it says both dimm slot 0 and dimm slot 1 are good even though there is only one stick of ram in the board, is this correct also if I move the stick of ram to the other slot the board doesn't recognise it. Also if I add another stick of ram in the other slot so both slots have 256mb in each it wont. I want to upgrade to 512 but dont want to spend any money if it wont work.
Any help would be appreciated
Brendan
Brendan14952021-04-11 11:10:41
23CR
The only jumpers documented I can find are the GDROM/ Net Dimm jumpers
jonhughes
1,156CR
I put 2 x 256 in a Dimm that was originally 2 x 128 to use in a Triforce type 1 and it just worked without any modifications. Triforce type 1 need 512mb so it worked for me.
23CR
tried putting another 256mb stick in but did not work maybe I need to look for a matched pair
