Negative voltage circuit help needed
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
hey guys
does any one have any info on how to go about making a negative voltage converter
+5v to -5v
there are far too many circuits on google and am not sure which is the best one for arcade use to go for
im thinking of using a LTC660
silverfox07862016-02-14 14:21:55
andrewsm
485CR
The IC ive used in past is a ICL7660 which is an 8 pin device. Depending on current you need, this will probably do the job with minimal extra parts. Will work as a negative bias voltage for say RAM etc but if you need more current then an actual power supply will be needed.
andrewsm
485CR
You could use one of those but then you have to filter and create the -V on pin 3. The ICL chip is a dedicated neg voltage generator so I remember there were only about 2 to 3 parts extra. Cheap as well
