netboot NAOMI without PIC?
big10p
Coins detected in pocket!
6,093CR
terminator2k2 said:
big10p said:
Hmm. I tried searching for that, but couldn't find them.
ive been looking and yet to find any...ive found some with 8 connections but not 10.....i can de-solder some off a scrap i/o board if you want? ill go and check it first....
Yeah, I couldn't find any 10 pin ones, either. Not to worry. I've got the other faulty board corn has given me, so I can pinch them off that, if needed.
obcd
3,830CR
If only one resistor of the 8 are bad, solder a normal resistor of 4K7 between the 5V and the pin of the microcontroller. You could use the microcontroller socket pins for that.
big10p
6,093CR
OK, I've had partial success at fixing this. I changed the opto chip for the Service 1 input, and now I get 5v on the micro controller pin - so this no longer shows as always on, in the input test.
The other faulty input was the P1 Down switch. The resistor for this was reading way too low in the resistor array, so I wired in a regular 4K7 resistor, as obcd suggested. I also cut the trace from the resistor array, as the low resistance in the array, in parallel with the 4K7 resistor, reduced the overall resistance (ohm's law thing, I think).
However, I was still getting a low voltage on the opto and micro controller pin, so I changed the opto (made a bit of a mess of this one, but I think it's OK - don't want to have to solder another one of these things, if possible!). I now get 5v on the micro controller pin (so the input shows as off, in the test), BUT when I press the 1P Down switch, nothing happens - still shows as off in the test, and still read 5v on the pin.
Well, that's as far as I've got...
terminator2k2
327CR
good work so far.....it may be that you fitted a faulty opto or used too much heat when you took it off one board and re-fitted it to the other....
check with your meter and compare to a working input....you will find where the problem lies.....start on the 60 pin connector and work your way through.....
i think the big micro controller chip is faulty on mine, as only 1 led lights up and the relay doesnt kick in when you apply power....
big10p
6,093CR
Yes, I think I must have damaged the opto. One of the input voltages is very low. As I say, I made a bit a mess of that one, so I don't think fitting another one is an option. Oh, well.
Re LEDs: I think both LEDs light on mine when only digital controls are connected, but only LED1 lights when analogue controls are connected, also. Any idea what the 2 LEDs indicate?
If your micro controller is faulty, I can pass on the one from the board corn gave me, if you like? I'm fairly sure it's not faulty, as I've tried it in my board, and get the same results.
big10p2017-02-15 09:30:09
terminator2k2
327CR
i was under the impression that 1 led will light when power is applied and the micro controller switches the relay which turns the second led on.....
i think the reason the led switches off with just the analogue connector , connected is it requires pin 1+ 3 of the digital connector to be connected for the i/o board to function.....
if you dont mind sending the micro, that would be great....send me a pm with paypal details and ill send some cash for postage.....
big10p
6,093CR
Just to complete this thread (which has wondered off-topic, somewhat
), I *think* I've managed to fix the IO board corn gave me. I tracked all the faulty inputs to 2 opto ICs, which I managed to replace without cocking it up. Think I had the iron too hot last time, which lifted a couple of solder pads.
I say *think* I've fixed because, while it checks out fine in the input test & in-game, these IO boards seem pretty flaky & temperamental, to me. One of the bad inputs was fine when first switched on, then after a while it'd flicker between 0 & 1 in the test, before eventually staying as 1 (pressed). I've done a bit of a soak test for ~6hrs, and all's good, but don't weant to jinx it by saying it's definitely fixed.
Time will tell...
Cheers!
ALLPRO
3CR
penrhos said:
FYI : Here's the steps I used to upgrade some V2.x Dimms to 4.01 that I posted over on Darksoft's forum. I've been told the FW upgrade will also work without a zero-pic but you'll get an error message on the naomi and have to warm-boot it to get the upgrade to work..
If you get stuck I can burn a Zero-pic or upgrade your Dimm for you.
FYI - You can also use netboot to force upgrade a 2.x net-dimm to 4.02 by following the process below, mine was 2.13:-
For reference if anyone else needs to do this....
Download transfergame.exe and Naomi bios 4.01 and 4.02.
01) You need firmware 2.x on your net-dimm (or non-net dimm if you swap the top PCB over) or you can't get into the network menu.
02) You need > D bios in your Naomi-1.
03) put a null pic into the pic socket on the dimm.
04) Go into setup menu and configure the network (I set mine to 192.168.0.100 as my router uses that range).
05) Plug the network cable from the Naomi dimm into your router, switch it all on and check you can ping it from your PC.
06) in a command prompt (as administrator) run transfergame 401.bin 192.168.0.100 -f -nl
07) your Naomi should display the message screen for updating from 2.xx to 4.01 if not repeat step 06 a couple of times.
08) press the "test" button to upgrade from 2.xx to 4.01, once complete power-cycle the Naomi.
09) Go into setup menu and check the Dimm firmware version - it should now be 4.01.
10) in a command prompt (as administrator) run transfergame 402.bin 192.168.0.100 -f -nl
11) your Naomi should display the message screen for updating from 4.01 to 4.02 if not repeat step 10 a couple of times.
12) press the "test" button to upgrade from 4.01 to 4.02, once complete power-cycle the Naomi.
13) Go into setup menu and check the Dimm firmware version - it should now be 4.02
14) Go into setup menu and configure the network to 192.168.1.2 and you're set for PI netbooting.
Notes:-
You need to set the three jumpers inside the dimm for network & use a known working zero pic.
If you plug the network cable into your router its a normal one not a cross-over as you use with a PI.
I tried using the single file PI netboot image to do this but it wouldn't work so I'm pretty sure you have to use transfergame.exe.
I disconnected the battery so the dimm forgets you've programmed it with the bios when you power-cycle it.
You cannot use this procedure to upgrade to 3.17 (why would you?) as the upgrade process doesn't work and you cannot go directly to 4.02 - YOU MUST upgrade to 4.01 first.
If you have a non-net dimm with firmware 2.x and access to a net-dimm, take both apart and remove the screw that fastens the top pcb in place (it's near the pic socket) - remove the top PCB and swap them over - then follow the same process. Once you've finished swap them back and you have a non-net dimm that'll boot from compact flash cards.
This process will not work for Dimm firmware version 1.x - that has to be done by swapping the bios chip over.
Hello boy,
I need help with all this ... or at least partially.
I updated 2 dimm to 4.01
one seems to me from 3.03 I'm not sure
and one from 3.17
using naomi_boot.py (without any PIC)
now I'm stuck with a dimm. 2.06 increased to 2.17 via gd.rom
I read in your guide that from 2.17 you can raise the firmware via net, even without PIC zero key? in the first lines it seems to me you describe it, but I can't. I don't understand where you are wrong, I always have error 31
