Noise filter
erzane
7CR
Hi,
What's the utility of the noise filter? Can it interfer with the monitor, and what happens if wire 1 and 2 are inversed? Also, pls can you check if my AC diagram is correct?
Thanks!
erzane2020-04-18 12:00:49
J69
281CR
Follow up question
I’m fairly sure I tapped 240v to my arcade power supply off the power cable before the line filter, rather than after. Will that make any difference? Cab works fine
ataridude74
265CR
I also have a cab with bad interference on the video and audio, do these noise filters go bad? is it worth replacing a 40 year old one? do they do anything at all?
5,332CR
https://www.emea.lambda.tdk.com/uk/faq/question.aspx?id=99
I think it's really to stop the cabinet throwing noise back onto the mains, as you've got SMPS and other stuff in there throwing out high frequency crap.
The filter will block high frequencies (making use of the earth connection to conduct stuff away).
If you put something before the filter, then it's straight onto the mains, so the filter isn't going to do anything (and your SMPS will be throwing sh*te into the AC mains).
Whether you ever notice or not is another matter. My dad's an amateur radio nut and he'd hate you for it
