NSM 'Ultimate' Jukebox query
devonpete
1CR
Hi, and greetings from North Devon.
I have an NSM 'Ultimate' wallmounted CD jukebox, working more or less OK since I got it last October, though it has glitched a few times for no apparent reason (lights sometimes go on and off, or the player freezes and judders. Turning the unit off and on has usually overcome this and it corrects itself.) But has now thrown a fully debilitating wobbly. The player won't engage along with the message 'CD player not detected'. I know nothing about these machines and am hoping that someone here might know of a mobile repair person who could possibly sort it out for me - someone preferably based in Devon. I expect it needs a full service anyway.
I checked the fuses as the layman's first answer to all problems and they are fine, but the securing lug on one of the holders broke, so the unit doesn't fire up at all now. I believe the fuse holder might be a Multicomp MCHPS-RH as it looks similar when searching the web, but not certain. Not that that helps much anyway, as I don't know where to lay my hands on one, and it wasn't the cause of the problem.
If anyone can suggest or recommend an available service I'd be very grateful. I can't ship the jukebox to a repair shop as I'm an OAP and have no helpers to manage its weight and size.
Pete
Ronnie Dent
1,206CR
Are all the power led's lit in the bottom? maybe a ram clear will help. I have 2 of these boxes and a scrap one so might be able to help with parts?
Ronnie
devonpete
1CR
All the led's were on, but with the loose fuse (the one on the right) is now preventing anything working. It would probably be pointless me attempting to correct the player problem as electronics are alien to me. Basically I hope to find expert assistance.
Pete
Ronnie Dent
1,206CR
Well I could have probably helped but I'm in Scotland, The only other guy I know I'm sure is in the North of England.
It could be as simple as re seating the plug or plugs on the back of the CD changer and same for the main board plugs, but you will need to sort that fuse out first.
devonpete
1CR
I've sourced an NSM fuse cap which should be with me in due course. Many thanks for your suggestions which I'll certainly investigate once the fuse is back in place.
Pete
devonpete
1CR
Just had a message from ebay seller in the US that the NSM fuse cap isn't available now. So the search for one continues. This could take a while. Pete
devonpete
1CR
Hi Ronnie, yes it's from the one on the right of the row of three. The small lug on it has broken off so the cap won't secure itself properly. If you have one going spare I'd be happy to buy one from you. I'll PM you and we can hopefully continue from there. Very much appreciated. Pete
devonpete
1CR
Thanks for the fuse cap Ronnie - very much appreciated.
I've solved the fault guided by the suggestion that the connection plug from the cd player might need looking at. I did and it was almost hanging off. I unplugged it and plugged it back again and bingo - everything's back to normal.
Many thanks everyone for your suggestions. And Ronnie for the replacement fusecap.
Happy days.
Pete
devonpete2017-06-20 12:54:36
