Operation Thunderbolt PCB corrupted
mickyc22
67CR
Im after some advice on an issue i have with Operation Thunderbolt PCB, the board doesn't boot it just comes up with corruption as shown in this video, i appreciate it could be anything, but any advice would be appreciated, I've done the obvious checked voltages/re-seated all the socketed chips, visually inspected it.
operation thunderbolt pcb fault - YouTube
Or is there any recommendations on a guru to fix it.
Many thanks
paulcan69
946CR
They have mask roms which are a bit known for failing
They need to be pulled out and tested
I think they can be a pain to read
Might need an adapter made up to test them
I know there was a repairer on here where he burnt them using normal roms
Might be easier to get him to burn a set
Then you can just swap em all
Might still be a ram fault etc
But you would be further forward
Search op thunder in tech section on here
