outrun graphic issues
PhilT
154CR
hi all
Had my outrun board repaired recently, was fully working but has already developed a graphics fault! Not got 10 hours on it
Plays fine, its the background sprites and text that seem to be all messed up.
I was wondering if anyone had seen this issue before and knew where to start looking, before i part with another wedge to get it repaired again. Thanks.
Below is when high scores are showing
bones
1,628CR
Hi, I'm no expert but looks like some information is getting lost, I would check you've got a good +5volt on the board first. If thats good and has been working ok you could try applying a bit of pressure to the board by gently pressing down in various points across the board, or if you're not happy with that I tap the board with the handle end of a medium screwdriver. If by doing this you see the corruption changing as you tap it's gonna be a poor connection on one of the socketed chips or more likely to be the big connectors joining the boards together. More often than not by carefully taking the boardset apart and putting it back together was generally enough to get them going again. I'd say though if you decide to separate the boards it'd be worth partially lifting each of the socketed chips and reseating them too as I believe oxidation can occur on the legs and socket . Hope it's something simple like that good luck
PhilT
154CR
I checked the voltage on the board, it was running at 4.8v so i bumped it up 5.0 measured on one of the ICs on the CPU board. It made no difference.
I can get into test mode but I cant read any of the text on the screen, its all scrambled so I cant see any of the diagnostic information.
dj_yt
787CR
My guess is that the CPU can't access the tile RAM. This will mean that either the tile RAM itself is faulty or the buffer chips between the CPU and RAM are bad.
You could try reseating the tile ROMs on the bottom PCB, but I would be surprised if that fixed the problem if I'm being honest. (ICs 99, 100, 101, 102, 103, 104). Reason being, from the screenshots you posted it looks like the tile ROMs are being read correctly, but the tiles are being rendered in the wrong positions.
Hope that helps - looks like another board fix though.
940CR
Does it get worse, the longer you leave it on? Mine went like that last year. Start of this season I turned on the cab and for a few mins it played fine, but then went like that again.
PhilT
154CR
When it first happened I left it playing to itself for a couple of hours and the corruption pattern stayed exactly the same even through power cycles. Powered it up yesterday though the corruption pattern has changed a little since it started happening, still looks pretty similar though.
Thats a good spot regarding the tiles being positioned incorrectly. Definitely some recognisable tiles especially on the high scores table.
I will do the easy stuff first, reseat the tile roms etc just in case its that.
