Outrun Wiring Question
Purity
The Oracle
17 (100%)
2,999CR
Was wondering if you Outrun gurus can advise me on some wiring on the Midi
I've been checking over my wiring and have found 2 wires not connected. The first is at the top of the 2A 100v fuse, and the second is connected to pin 3 on the SSR board. I did this very rough power map diagram of my wiring so I could try and work out things. It is only the power supply side:
Member Seanr28 has kindly had a look at his Outrun Midi and confirmed that both those wires go to the transformer block in the cabinet.
Now, what I'm assuming is that it looks like my transformer block is potentially not an original one, and maybe doesn't have the output for those connections, so someone decided not to wire them up.
Going off the wiring diagram, it looks like the missing connections are all related to the solenoid (force feedback motor) and power via the SSR board which feeds the motor. So I assume it is ok just to leave them disconnected, as I have no intention of using the force feedback
Would you guys agree?
Purity2017-04-15 17:22:01
ColinD
6 (86%)
1,367CR
Sounds about right..... the Mini does not have a motor afaik but has a knocker solenoid, the Upright does have a motor which vibrates the whole steering left and right. Having the wiring missing should not cause any issues if you don't need this feature.
Purity
The Oracle
17 (100%)
2,999CR
Thanks Colin. It does only seem to be the connections labelled DC motor and Solenoid, so I think I should be ok without them connected
