Hi, This is my first step into getting my own machine up and running and I've fallen at the first hurdle. Apologies for the long post.
I bought a pacland PCB (including jamma adapter) and got myself a switching PSU a JAMMA harness and a video adapter to hook the board upto a pc monitor to test it.
First try it all worked perfectly, there was a bit of flickering on the display but I put that down to the video adapter. Whilst it was running in attract mode I went to test the output voltages on the PSU but before I even got chance the psu started to hiss and smoke started coming out of it (about 2-3 mins after being on). I switched it off but it was too late the psu was now dead (17 quid off ebay so i thought ok, you get what you pay for, lesson learned).
I then wired it up to a spare PC power supply and the game booted perfectly, no flickering at all. I then coined up and started a game, all working great. I then turned it off to wire up a speaker as I hadn't tested the sound yet. I turned it on again but no sound and the colours started to bleed a bit so I turned it off disconnected the speaker and turned it back on again, after 30 secs or so it started to bleed again. I turned it off and on again and this time the video was just in black and white. I checked all the video connectors were sound (which they were) then turned it off and on again and now there is no video output at all.
I have checked the voltages at the board and the +5v reads ~4.5v but the +12v reads 0.05v.
All the caps look original, could it just be that I need to replace them. Have I done something blatantly obvious that has screwed the board or have you any suggestions on steps to go about fixing it?
Any help is appreciated
TLDR;
Bought a Pacland PCB, wired up, working but psu died. 2nd psu on and PCB working fine until video colours started to bleed then went black and white, then no output. 12v at the board is really low. Any ideas please?
retrob2016-06-30 20:37:26
TLDR;
