Pacman Z80 Sync Bus Controller
Nico24
2CR
Hi,
I'm trying to code Pacman in Verilog from the ground up, as a learning experience. I'm confused about the Z80 Sync Controller board. The schematic shows (in the red box), I think, a 74LS130. But this detail is not on the actual board. Any ideas how this can be bypassed or how it actually figures in the design?
Nico24
2CR
You, Sir, are a legend!
Many thanks. I was also confused by the UO rather than the strike-through zero!
All makes good sense.
Nico24
2CR
Question about the above diagram:
How does the U7 374 operate in the above circuit?
I can understand that D0 to D7 gets passed to BD0 to BD7 if the U5 244 is enabled.
I can understand that the opposite direction is possible with the U6 374 enabled.
I can't understand how the U7 operates given:
- The D and Q pins are connected to the same wires/bus - is it not just feeding back to itself?
- I could understand if the Q side was connected to the BD wires, but they are not.
Any help appreciated.
philmurr
48 (100%)
2,378CR
First thing to understand is that the SBC is a bidirectional circuit, D0-D7 and DB0-DB7 can be both inputs or outputs.
Study where the SBC sits in the main Pacman schematic, and read up on Z80 timing to see what's clocking and enabling the 2 flip-flops
Nico24
2CR
Thanks Phil,
Yep - I can see it's bi-directional. It's that one 374 that's just confusing me, since it's just connected to itself. I'll keep cracking away at it.
Nico242020-10-17 03:31:20
