PCB clean
T-65
5CR
A very noob question but I'd like to clean my newly acquired boards at some point, what's your preference for cleaning products and are there any pitfalls to avoid?
devtty0
222CR
not much help, as I have a few boards to clean, but reading the wiki here:
http://wiki.arcadeotaku.com/w/PCB_Cleaning_101
really put me off! .. it kinda says that if the board is working, then you have to consider if its worth breaking it, just to have it clean, and if its broken, do you want to risk breaking it further!
I've seen people on here talking about 'pcb baths' though as well?
T-65
5CR
Interesting article, thanks! I was thinking it might be worth a light clean with a soft brush and cotton buds, as long as I'm careful. I liked the idea of removing some of the years of dust.
grobda
1,061CR
I was reluctant to wash boards to begin with, but after trying to work on some faulties with pigeon sh*t all over them I decided it needed to be done. I just use lukewarm water and an old toothbrush then leave them to dry in the airing cupboard.
I generally wash all faulty boards now as it makes them easier to work on.
For gunk and old flux ive got some servisol PCB cleaner.
If they work and they're just a bit dusty I leave them alone. I've got a pretty filthy Juno First I'm tempted to wash before I sell it as its embarrassing to look at.
sukhbir
46 (100%)
1,733CR
if you are going to use a soft brush i would make sure you have a earth strap on otherwise the static could damage the chips or degrade their life.
5,653CR
If anyone wants to make a nice post on cleaning boards, tools of the trade and a nice loads of pix for a before and after, i'll make sure it is made a sticky!
2,264CR
I've seen some incredible results from pcb's that have been cleaned in an ultrasonic bath.muddymusic2014-01-21 14:18:12
aeroflott
A different league
16 (100%)
1,058CR
There's many threads over on KLOV from our American cousins who literally wash their boards in the sink with some washing up liquid, warm water and a brush. I've yet to do this to all my boards, but did wash a Nintendo sound board - it came up sparkling. After being sat in an airing cupboard for a day, it fired up no problem.
I removed all removable chips before washing though. Here's a guy who loves a bit of water on his boards:
aeroflott2014-01-21 14:31:07
bbz149
26 (100%)
1,608CR
F@ck me, can the guy not bloody speak!
trm
2,877CR
Washing in the bath, top shelf of a dishwasher, isoP bath - all have worked for me. These things are way tougher than you'd think as long as you observe static precautions, which isn't really necessary when they're wet.
The only caveats I'd mention are:
Dishwasher - don't do the dry cycle. Towel and a few days in the airing cupboard.
Remove all socketed components and definitely all batteries.
Ideally horse hair paintbrush.
jonhughes
1,156CR
Well, here's what I do.
Turn the oven on to the lowest setting - usually around the 50 degrees mark.
Take out all the socketed chips. Fill up the sink with hot water & detergent. Dip a paint brush in the solution and spread over the surface to 'soak' the board in foam. Use a tooth brush over the entire area working on the chip sockets. Once happy rinse in hot water and shake until the board stops dripping (don't drop it). Pad down with a piece of kitchen roll and place in the oven for 15 to 20 mins. Blow into the chip sockets, you'll know if there is any water remaining. While the board is still warm spray the chip sockets with contact cleaner.
They come out great and have not had a problem with one yet .
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I Would not have the balls to do that
T-65
5CR
Great tips, if I have the balls to try! I would of thought soap would accelerate any damage so I guess it is critical to rinse and dry thoroughly. I think my Chopper 1 board is a bootleg so maybe I'll try that first!
trm
2,877CR
As long as you wash it all off afterwards then it's not going to have long enough to do bad. Although most soaps are chemical bases so they'll neutralise any stray battery acid leaks :) But then you end up with insoluble salts which give you the white stains. :(
