PCB corrosion/oxidation?
cosine
14 (100%)
595CR
Recently acquired a 1 slot NeoGeo board in rough shape, and decided to remove the battery as it's probably dead.
Removed the cart slot, and desoldered the battery to be presented with this:
I half expected this on the battery, as it was original, but there's some corrosion or oxidation on the Yamaha chip, which might explain the intermittent/ crackly audio.
How would I go about cleaning this up? Cheers.
Ace`
PlanB contributor #1
40 (100%)
4,038CR
Typical battery leakage, white vinegar to neutralize it and then what Kman said to clean it up. The yamaha chip will probably need to be replaced and you can also check the traces under it when you remove it.
cosine
14 (100%)
595CR
I had a sneaking suspicion that the Yamaha would have to be replaced, it's pretty tired looking. Thanks for the pointers guys.
13CR
White vinegar ... not isopropel alcohol? any advantages.
whilst we are on the oxidation topic what about tracks. at what point do you go for a track replacement or jumper connection?
Battlezone
410CR
I bet the Yamaha chip is just fine provided the legs are still making good
contact with the PCB traces.
The die itself is in a small area right in the middle of the package. The package
was hermetically sealed after manufacture and is as tough as nails (as you'll
know if you've ever tried to file into one). Just my penneth as a chip designer.
That's not to say it couldn't do with some love, just don't assume you'll
have to bin it.
Purity
The Oracle
17 (100%)
2,999CR
Agreed, if it is an alkaline battery you need to be using an acid to neutralise so white vinegar.
Rinse area with de-ionised water, and use IPA for cleaning afterwards
andrewsm
485CR
The chip looks ok for a good clean as said above but the first row of pins with the greenish coating would need all the solder cleaned out and re done? Prob a bad connection looking at them
cosine
14 (100%)
595CR
Battery was a Ni-Cd, so still white vinegar?
Nice to know the Yahama is somewhat bomb-proof
I ordered a spare anyway, in the event it is dead, but I'll give the existing a good clean and see if things improve.
