PCB White moisture damage
Purity
The Oracle
17 (100%)
2,999CR
I've acquired some PCB's and some of them have obviously been in damp conditions as the solder side of the board has white moisture damage on some of the solder eyelets so clearly some water corrosion.
Does anyone have any tips for cleaning these boards up? Is it worth it?
TheDaddy
14 (93%)
7,230CR
Really depends how bad it is. I remove all chips and solder and use a fibre pen to clean and look under a microscope or magnifier to see how bad it is.
Dave.
TheDaddy
14 (93%)
7,230CR
Yeh happens alot. May be time consuming so depends if the boards worth it, still remove all chips and clean , fresh solder and hopefully be ok. You can never be 100% as corrosion can sneak down the tracks so worth testing continuity.
Hope this helps,
Dave.
P.s out of interest what games are they ?
