Pic Programming
Chopper79
668CR
Hi,
Can anyone here program a pic chip, or know someone who can. The pic chip is a: PIC16C54C 04/P, and I have the 4 digit code to be programmed onto it. Or last resort, maybe someone can recommend a pic programmer, that will work with this pic. Any help appreciated.
obcd
3,830CR
The 16C54 is an OTP microcontroller (one time programmable.) You better switch to the 16F54 which uses flash technology and can be programmed multiple times. That being said, I doubt that anyone will be able to program a device with a "4 digit code". Most manufactureres that deliver devices with buildin programmed microcontrollers don't deliver the program that is in those devices. In fact, they usually lock those devices against readout to protect it. So, your only option to get a programmed a chip is contacting the company that makes them and asking them for a replacement.
The 4 digit code is only meaningfull for the manufacturer, unless someone reverse engineered the device. It might help if you would tell what it's used 4. Sega protection chips for instance have their code floating around on the internet.
Chopper79
668CR
Thanks for the info. It's actually an ID chip for a barcrest fruit machine. They removed the original speech from machine,,via a eprom firmware and ID chip update. I want to put back to original. I have the original rom files for the eproms, but am clueless about reprogramming the ID chip.
obcd
3,830CR
As it's purpose is probably protection against illegal use of the firmware, they likely will have protected the pic against readout. Your best bet is someone who distributed those machines and might still have the original pic's for sale.
http://www.benl.ebay.be/itm/USB-PIC-Programming-Develop-Microcontroller-Programmer-K150-ICSP-FREE-PIC-UK-/122538708290?hash=item1c87e04d42:g:QU8AAOSwwzhZOUzR
That programmer does the 16F54 and it's not all that expensive. This still leaves you with the problem to find the code to program into it.
