Piranha pcb help
Belike
101CR
Piranha was in the first 3 arcade games I ever played back in the 80's in our Amusement Park. :D(the fu..ing hungarian government closed it yesterday after 170 years of history). :'(
After so many years of searching, I found a pcb and finally yesterday I had some time to solder a jamma adapter for it.
The pcb is a non-worker, just garbage on the screen. :-
There is a daughterboard on the top with an empty socket, I tried to compare it with some internet pics (klov, crazykong.com), but it is not clear, that it is originally empty or something has to be there.If anybody has a similar pcb or some pics please help! ;)
If the pcb repair guru's have an idea what would be the problem or where to start inspection, it would be also great. :D
andrew96
899CR
does that empty socket pins go down to the mainboard? if so that was a trick they used to use a wirewrap socket for cheap pins and nothing goes in the socket as it is supposed to be empty! if no pins go down to the mainboard then it is likely there should be something in it! look carefully at the dust in the socket, that can give clues if it has ever had a chip in it!
so the board is non booting, my first guess is program roms or program ram fault, check the processor is running, reset/ halt clock is all as it is supposed to be first
cheers
Andrew
4,058CR
Given the processors under that daughterboard, this is going to be fun
It certainly doesn't look exactly like PacMan hardware which is a shame as otherwise I'd be tempted to stick pacman ROMs in, fix the board and then put the Piranha back in. Can't do that with the daughterboard though as it's probably doing crude encryption.
Belike
101CR
Thanks for the tips Andrew.
The pins go down to the mainboard and attached to another socket, seems like they used it just for that.There are also 2 jumper wires coming down from the daughterboard, it was already repaired some day.Compared it with klov Piranha pcb pic, the daughterboard solution is original.There are also some schematics, but I'm not too good in reading them.
andrew96
899CR
ah right, well also look at the dip switches, sometimes a dip can be the game freeze switch, and if on game will not even boot because it it being told to freeze! I see some dips are switched, but don't have any info on that board and is not one I have seen to repair.
Belike
101CR
Thanks Andrew, I tried the dip switch trick and replacing the processor from a working pcb, but nothing changed.
This what we have under the daughterboard.
There are also some socketed HMI-7611-5 proms on the board, do we know anything about these?
andrew96
899CR
check the reset line TO THE PROCESSOR with a logic probe or oscilloscope, check the clock pulses are there with a oscilloscope, you cannot 'reset the clock' as you say! you have to check there correct and present. If your unsure then best send it to someone for repair that knows how to do repairs or your end up doing more damage very easily!
andrew962013-10-05 11:47:53
