Point Blank 1 hell :-)
cmh
3CR
Hi Everyone,
I bought a PB1 cabinet a few months ago, to take me back to my teens as it was my favourite game when I was a kid :) It works well enough to play, but has some niggles that are really bugging me.....
1) It does not have the original namco guns, but the people who (only partly) refurbished it swapped them for Recoil SFX guns. Everything on them works, apart from the recoil.
I looked inside the cabinet, and each gun has 6 wires coming from it - but 2 of them (the grey and orange wires) have not been connected to anything, so only the remaining 4 make it to the board. I am hoping these are the power to the solenoid, but I really can't tell - would anyone know what these 2 wires are supposed to be for? I found installation manuals for the guns, but no mention of what each individual wire does :-(.
2) As I was investigating the issue with the guns, I was looking at all sorts of diagrams and schematics for PB1, which all show what the original components inside the cabinet are supposed to be - however, this machine to my surprise seems to be missing lots of components:-
a) There is no service bracket component, so I can't enter the menu to calibrate the machine or find any knobs to adjust the volume.
b) In fact, there only seems to be the main PCB and the Position board - no EMI assembly, no gun assembly etc etc - so I am really struggling to work out how to understand this cut back setup.
All I want to achieve is adjust the volume for the right speaker, get into the configuration menu and get the recoils working.
I have attached a photo - but it would be amazing if someone could give a hint on how I could achieve these three goals?
Sincerely,
CMH
IanH
277CR
I cant remember for sure but I don't think Point blank has recoil, had one at work but its been a few years since it got sold.
  • Like
Reactions: cmh
Sbdesign
SEGA collector
16 (100%)
1,722CR
Im guessing this isn't the namco original cab looking at it, the cage etc is missing.
Test buttons and volume can be added on the jamma connection
Regarding sFX guns, I have instructions somewhere i'll dig up
IanH: it does have recoil.
  • Like
Reactions: cmh
cmh
3CR
Hi All, sorry for the delay in replying - busy week at work!
Thanks to Jasonm737 for the pictures, they do help a bit. It shown the guns connect to the Game/Gun PCB, but this is missing from the cabinet. 4 of the 6 wires connect to the V147 position pcb (which is missing in my case). I think here, I just need to try and understand what the two disconnected wires on the gun need to connect to).
@sbdesign thanks for the tip - would you be able to explain how to get the volume controls and test buttons working through the Jamma connector please (I am not very experienced here).
Any advice is gratefully received,
Sincerely,
CMH
G-man
181CR
The volume control is on the main PCB. Look just under the heat sink (with the words 'point blank' written on it) and the little round disc is what you need to adjust.
  • Like
Reactions: cmh
cmh
3CR
Hi G-man, I did not know about that black dial, thank you
The issue I have is that the sound form the left speaker on the cabinet is much louder than the right speaker. The service bracket (according to the Point Blank Manual) had separate volume control knobs for each speaker (which now makes me wonder how, if they are going through a single master volume dial, how they can give different volumes). I know that the bullet sound for the left gun comes out of the left speaker only and the bullet sound for the right gun is coming out of the right hand speaker only (seemingly proving they are working independently). I was trying to find a way to separately adjust the volume of each one.
Hi Sbdesign - thanks for the diagram! OK I learned a lot just from your picture (this is the first cabinet I have ever owned so I have to research everything :)). So the Part side is the top side (numbers) and the solder side is the bottom (letters, e.g. R is the pin under neath 14).
I checked them and there is nothing at all connected to either R or 15. So does this mean I need to buy two buttons (or maybe on/off switches?) and connect them up? e.g. from the button (which would have 2 wires I guess) one wire goes to the pin and the other I can join to pin 1, 2, 27 or 28? (There are already some wires connected to the 1,2,27,28 "ground" wires
Sorry for such basic questions I really appreciate the advice guys
Sincerely,
CMH
cmh
3CR
Thanks Sbdesign,
I see what you mean - a "on/off" would be for the Test switch and the "button" would be for the Service switch I guess :)
Was my idea OK, to ground them to the 1,2,27 or 28 pins?
Kind regards,
CMH
Sbdesign
SEGA collector
16 (100%)
1,722CR
Yes any ground I believe is ok. And yes test on and off switch.
Many games just have 2 buttons, like model 2,3 sega boards.
My mortal kombat 2 / point blank have switches.
  • Like
Reactions: cmh
cmh
3CR
OK I have ordered a switch and a button, I just hope my soldering skills are up to it without wrecking the board.
I also ordered a 12v 5A power supply, to connect up the solenoids in the SFX guns and see if that springs them into life (easier for me to do that than try and work out what to do about the missing boards etc). Might be wasted money and not work, but worth a shot.
God those wiring diagrams in the manuals are tough to understand!
Thanks so far,
CMH
cmh
3CR
Update:-
the 12v 5A power supply arrived. I momentarily connected the sliced off orange wire and grey wire from the SF-X gun to it and the solenoid fired! So at least I know the recoil mechanism is functional. I had to take a 50-50 gamble on which of the wires for the gun was +ve and which was -ve, as there is no reference to this in the documentation - I chose the orange one to be the positive one.
Getting closer
obcd
3,830CR
Just be carefull with that. If the recoils are energised 2 long they will heat up and it's windings might start to melt causing a short. Time crisis II guns even have a thermal fuse integrated in those coils. It opens when the coil becomes 2 hot.
cmh
3CR
Hi Obcd,
Cool thanks for that tip - I just tapped them together for a split second, so hopefully no melting!
I am having a realt nightmare deciphering the next step, because my cabinet is missing the EMI board and a few other items!
In the SF-X inspections, it says to disconnect the +ve and -ve wires "on the 24v transformer that run from the Gun Input Drive PCB attached to the Game PCB and connect them to the +12v DC on the cabinet power supply"
Trouble for me is, in the Point Blank manual there is no "Gun Input PCB" defined. The closes I can see is the "EMI PCB" and the "Position PCB Assembly".
Trouble for me is, that my cabinet only has the Position PCB Assembly - it has no EMI board, because the person who refurbished it somehow put it together missing some parts :-S
Also, I am not sure what the "24v transformer", I fear it is a part that is again missing. The only "power" I see is a socket in the back of the machine that you connect to the plug in the wall. This is attached to a box (which I guess is called a transformer) that puts out a variety connections, I found a decent picture of it online (posted below). I can't even see a 24v connection on there, just things like ACN etc.
It has a bunch of wires already hooked up to this power supply, including the +12v DC output - which connects to the JAMMA connector. I know I cannot connect the gun's solenoid wires directly to this power supply, as the solenoid would be constantly "on". There must be something going on on one of the boards that controls when to send through the pulse of electricity.
I just hope it is not a board that I am missing :-( Hopefully this pulse is sent via some electric cleverness in the V147 Position board (which I do have). I know the gun's trigger wires go into this board, so I am hoping that this board then send the pulse to the solenoid when it hears that the trigger is pulled. To me, this means I have to somehow work out how to change this board from 24v to 12v
Any advice always welcome :)
Sincerely,
cmh
3CR
I have decided to give up trying to figure it out on the board, I have ordered some relays on ebay, which I hope to wire to the trigger and then power the recoils independently - lets see how it goes
cmh
3CR
The solenoids turned up, I got very excited that I might be able to get the recoils working.
I connected up the 12V solenoid/power in the gun to the relay, and then connected the control terminals on the really to the trigger wire of the gun. My plan was, that when the trigger was pulled, a short 5V pulse would go into the relay and initiate a burst of 12V to the solenoids.
However, I was gutted to find out that it did not work
First of all I thought it might be a bad relay, but I tried another one, and it still did not work. I know that the controller on the relay waits for current/voltage as it's signal to activate - but I decided to check the trigger wire for voltage. The weird this was, that even when the trigger was not pulled, there was still several volts in the wire - so from the relay's point of view, there is always a signal there, so it leaves the 12V circuit constantly "on".
Now I was expecting the trigger wire to be at 0V until the trigger was pulled, but surprisingly there was voltage there even when the trigger was not pulled so I am very confused.
It might be that I did something wrong, but for my basic brain I was not expecting there to be voltage without the trigger being pressed
Back to the drawing board
