Can anyone help me out?
My 28" Polo Star monitor won't turn on, and gives the famous ticking sound.
I've searched the forums and have done the following.
- Removed the HOT and dummyloaded the B+ with a 40W bulb from R153.
- At R153 I measured +/- 145V, and at the centre pin of the (unplugged) connector to the yoke I measured 119V, which I adjusted to 116V as I understood that's the correct voltage.
- Replaced the HOT (as the old one measured faulty) with the BUH1015, which the supplier said was a correct alternative for BU2530AW.
- Checked the T1 transistor (measured ok, replaced anyway) in the PSU section.
- Checked the transistors on the switch board, T1 and T6 were faulty, so replaced these.
- The polycap C101 tested good, so I did not change that.
After reconnecting the board, still the ticking sound, no difference.
I am stuck at the moment
Can anyone point me in the right direction?
