power supply capacitor
jengineer
49 (100%)
1,207CR
I have a transformer from a Rowe Ami jukebox, I need to re-cap it
this big brown cap has x5 tags, x4 of the tags are used, what kind of cap is this?
x2 wires are going into the transformer, 1 wire is going to the rectifier and 1 is going to the output plug,
any ideas?
thanks in advance
jengineer2015-03-15 16:02:17
jengineer
49 (100%)
1,207CR
ok, do you know which ones re neg/pos? and what kind of silicon rectifier do I need to buy, post a link up stu, is it neccesary to change the rectifier?
obcd
3,830CR
If that rectifier is a selenium one, those are known for being unreliable. You will need a Silicium bridge rectifier that can handle the current and the voltage. You can measure the AC voltage on the transformer windings. For the current, you could look at the fuses. Their value will be higher than the needed current, so if your bridge rectifier can handle that current, you should be fine.
caliskan
3CR
jengineer,
you can try changing the capacitor first since you’ll have very little work do
on that as compared to changing the rectifier. However, changing the rectifier
might be necessary here since it looks really old. Rectifiers are not prone to
such abnormal behaviour but old age kills everything, doesn’t it? Please let us
know what you found out, for future reference.
low cost pcb
caliskan2015-05-04 17:20:51
RaveN
1,325CR
What some of them have suggested will cause a fire hazard so please ignore.
It's all fairly simple.. You have a multi-capacitor - a capacitor that has encased multiple different capacitors. They will have a common GND and different caps denoted by the different symbols (usually written on the outside of the cap). This is what you'll find on many B&W monitors. If you connect together the 3 outside tags (like anj suggests) it will likely blow up.
You can't find replacements for these now, so what many people do is remove (or leave them in place for asthetics) them and replace with the 3 or 4 seperate caps that would have the same individual values.
I don't understand the significance of the bridge rectifier, unless it is dead then leave it alone. You don't change a bridge rectfier because "it looks really old", or because you suspect it's not silicon!
obcd
3,830CR
Replacing a selenium bridge rectifier is like doing a capkit on a monitor chassis.
You replace them because you know they have a high failure rate. It all depends a bit if your intention is to keep everything as original as possible or if it is to create something that works reliable for some years. If you go for the first, you might leave it untouched till the next failure with a rotten egg smell.
jengineer
49 (100%)
1,207CR
cheers for the input guys, ok originally the fault was 18v at the jukebox mechanism, metering the output at the power supply it was only throwing out 18v, I changed the cap the way anj suggested and this works a lot better with there now being 25v coming out so the mechanism is now working
but it should be throwing out 30v
