From memory, there's a 2708 eprom on the smaller board, that requires -5v and will die if it's powered up with it missing.
Infact, the rams and eprom that require 3 voltages state that the -5v should be applied first or simulatenously to the other voltages. Although I doubt the 7905 will affect this enough to worry about.
Not completely necesary, but I would place an input capacitor on the 7905 as well, 1-2.2uF tantalum or similar, as you're not mounting it on the same pcb as the SMPS filtering.
