Powerdrift help and maybe IC needed
frothmeister
58 (100%)
938CR
I've just managed to get at my Powerdrift again and refit a working monitor into it after a while of it being out of action.
It seems as though it has a slight graphics & sound issue though. Sometimes a load of small black lines keep appearing for a short time before disappearing again.
This seems to happen intermittently but fairly frequently and it always begins at the top of the screen where the sky is (all the way across from left to right) and comes down maybe 25% of the screen, sometimes when it happens I think it's a little bit more than that and sometimes it's a bit less.
I've been into the test mode and run the memory test and everything is checking out OK except for ROM IC26 which it says is BAD. (PLEASE NOTE: I'M SURE THIS HAS ALWAYS BEEN THE CASE SINCE I BOUGHT THE MACHINE ALTHOUGH I DON'T RECALL ANY GFX GLITCHES BEFORE). All the Video board RAMs come up as OK though - see pic. I have located this chip (also pictured) and tried cleaning and reseating it but that hasn't made any difference.
I also checked all other connections on both boards and ensured all other chips were properly inserted. Unfortunately that's about the limit of my technical ability and I don't have any equipment at my disposal other than a cheap multimeter.
Another strange thing is that I also went into the sound test and it seems as though quite a few of the samples don't seem to play (THIS I HAD NEVER CHECKED BEFORE). I have never noticed though from playing the game that any sounds are missing, which is pretty weird. All background music and sfx seem OK to me although I never played this game at all in the arcades BITD so maybe there should be extras that I've never heard before.
I tried loading it up in MAME but couldn't get the car to move for some reason, it just stuck there as all the other cars sped off however all sounds that I could hear (attract mode, coining up, speech, music and sfx) sounded exactly like they do on my cab up to that point
It's getting late and this is probably not the best constructed post but I guess what I'm saying is could the IC26 fault be related to the intermittent graphics glitches I'm getting? Or could it infact relate to sounds that are missing from the game that I never even knew about?
And finally if it is likely to sort out either of these two issues would anyone be so kind as to burn one of these off for me if I bunged you a few quid to cover costs?.
It's not (the graphics glitch) a fault that is that bad it makes the game unplayable but it would be nice to eradicate it if possible. Once you're playing it you hardly really notice it, even when it does happen as it's on a section of the screen your eyes don't even look at very much. It's most noticeable when the game is in attract mode.
Thanks guys
Danny
