Problem with fruit machine
Pharo
266CR
Hi
Thought I'd post here after searching Google and I'm not a member of any fruit machine forums so still stuck so hoping some of you fellow members know a bit about fruit machines.
So here is the problem I'm not into fruit machines but got two when buying a pinball machine which I duly gave to my friends.
Last week one of my mates who I gave the machine to which is a Fun In The Sun £250 jackpot machine said it had been sitting to long doing nothing as it didn't take the new pound coins so I got him a like for like coin mechanism which is a cash flow 126,fitted it for him and it took the new pound coins so happy days till later on that night he calls and says it's not paying out winnings so had a quick look and it seems the 20p were going into the hopper not the pound coins they were going straight down to the the bottom cash box.
I did a hopper dump thinking that might be the problem no joy still did the same.
I left it as I had other things to do went back up last night and he had been fannying about with it ,this is a fella who if he sees something saying wet paint he would have to touch it to see if it was.
So he tells me he found the instructions in the machine and decided to go into the test menu and to the coin in test now the machine recognises all the coins that go in when in test but still go down to the bottom cash box but when out of test and try to play it all coins just go out to the pay out try doesn't accept any.
So if anybody has any ideas or tips that would be greatly appreciated as I said arcades and pinballs are my thing so at a lost.
Thanks in advance Brian.
Ronnie Dent
1,206CR
Brian, there is a routing plug in the side of the mech you need to swap the one from the old mech into the new one, it's a plug with wire bridges on
Ronnie
Pharo
266CR
Hi Ronnie I did that when I fitted the new coin mech in,it was taking coins just to the wrong places ie 20p into hopper £1 coin into bottom left cash box and 50p and £2 coin into bottom right cash box and it was giving credits now it recognises the coins in the coin in test and puts them down to bottom cash box none go in the hopper but when you come out it all and go to play again all coins go into payout tray.
Any other ideas on what it could be.
Cheers Brian.
qjuk
51 (98%)
2,134CR
If I remember rightly, some of these Cashflow Dfx coin mechs can have the coin routing programmed electronically therefore doing away with the rectangular routing plug on the front of the mech. I don’t think by inserting a routing plug will make it over ride any electronic setting.
1. Check to make sure you are using the correct routing plug as a lot of machines have two plugs hanging off the coin validator connector (one for Mars mechs and the other for Coin Controls).
2. It could be you are using a mech that has the routing programmed directly into the mech. You’ll need a Mars programmer to alter it. Try a different mech if you can.
Pharo
266CR
Hi thanks for the reply,I've tried putting the original coin mech back in the way it was originally with the routing plug in where it was and that is spitting the coins back into the cash tray when before it took all the coins apart from the new pound coins it's not even taking the old pound coins now that's how I think my mate in his wisdom of pressing buttons that he knows nothing about what he doing has somehow invalidated all coins.
Thanks again Brian.
Ronnie Dent
1,206CR
If you think he has messed the settings might be worth shorting the battery for a few seconds or fitting another game card temp, I assume it's scprpion 4?
Pharo
266CR
Hi Ronnie I must be having a blonde moment but what is a jumper wire battery is it something you can get out of Halfords or something.
Apologies if this is a stupid question.
Cheers Brian
Pharo
266CR
Ha ha thought it was something like that, you would think I would know with the amount of pinballs I've had through the years where a loose wire has shorted something.
Cheers Brian
