Problem with Gunmaster PCB [Solved]
tdelage
2CR
Hi guys,
I recently got hold of one supposedly working Gunmaster JAMMA PCB (Metro Game Corp 1994). Problem is when i'm connecting this card to my supergun and switch on the PSU, both leds on the supergun (indicating availability of +5v and +12v on the JAMMA connector) quickly fade out and the PSU goes to safety mode and drops the voltage to +1.3V approximately. When this happens, PSU must be unplugged as fast as possible otherwise the internal fuse ends up blowing and the copper tracks carrying voltage on the supergun start to overheat big time.
I sense the PCB must have something like a short circuit of some sort but i have no clue where it could come from. Could a bad capacitor be responsible of the instant PSU drain i got when switching on the PCB ?
Thanks for your input and advice :=)tdelage2015-04-04 13:50:15
obcd
3,830CR
Yes, a bad capacitor could cause this, bit so could pretty much every other ic that is connected to 5V and GND. It might be worth measuring the resistance between 5V and GND, and the resistance between 12V and GND to see if the short shows up like that.
If you can measure the short, disconnect the board and measure again on the board. It might be the connection that shorts one of the power rails.
To find a shorted component on the board, you can power it up with a 5ohm 10W resistor in serie with the 5V supply connection. The resistor will limit the current, but there should still be enough current to heat the component that has the short. The IC that burns it's logo in your finger will likely be bad. A good capacitor shouldn't heat at all. Some components like ram chips even heat under normal working conditions. Usually, there are several on the board that can be compared.
tdelage
2CR
Problem is solved ! It was indeed a few bad capacitors connected to the +12v line on the PCB that were short circuited.
The game is now running fine showing its full glory ! :=)
Thanks very much for your precious advice.
tdelage2015-04-04 13:53:36
