Problem with my Gorf, please help!
Brewman
14CR
Hello
I took out the game PCBs to check if the U15 had a heatsink which it does but now I've put them all back in mission 1 and 2 don't work. It just starts at mission 3. I hope I haven't damaged anything.
Any ideas what could be up please or what to check?
Shinydaz
814CR
I'd start with pulling the boards out again and try and clean the edge connectors and where they plug in. Mine had bad corrosion on the top 2 molex type connections and ended up fitting new connections.
bonehead
I'll get pix tonight
50 (100%)
1,729CR
It shouldn’t matter what order they go back in the cage. As mentioned try cleaning the contacts and make sure they are pushed all the way Back into the cage.
