prom help.
sukhbir
46 (100%)
1,735CR
hi all,i need help programming a prom(N82S147AN),its from a original rolling thunder pcb and it use is to select the data for colour pallete.my programmer cannot burn this prom,any help in programming this chip would be a help,thanks.
Lurch666
21 (100%)
4,517CR
That's going to be difficult.
I couldn't find any modern programmer that handles these sort of proms.
I was lucky enough to find an old pinmaster 48 on ebay that does them.
patzik
391CR
have you thought about making an adapter board for it?
I have made some adapter boards for several proms (82s123 82s129 82s131) and they work fine. They allow you to use the winbond 27c512-45 eeprom. Looking at the pinout this should be possible for this prom too.
Macro
2,016CR
Look up the equivalence table (on the web in multiple places)
Code:
512*8
	A0 |1   20| Vcc
	A1 |2   19| A8
	A2 |3   18| A7
	A3 |4   17| A6
	A4 |5   16| A5
	O1 |6   15| CE/
	O2 |7   14| O8
	O3 |8   13| O7
	O4 |9   12| O6
	GND|10  11| O5
	   Signetics     MMI     TI       Harris  Raytheon  AMD      National  Intel
	TS 82S147 (60ns) 6349-1  28S42    7649-5  29621     -        74S472    -
	   82S147A(45ns) 6349-2  -        7649A-5 29621A    27S29    74S472A   -
Code:
so you need to find one of the equivalent chips that your programmer can handle.
Code:
I only have 82S141 in my spares box, and they are the open collector version (rather than tri state), and I don't think my programmer does them anyway!  (will sometimes work, depends on how it's being used in the circuit)
Code:
Code:
