I have an ATX PSU in a cab and wondered if I should earth the casing? The casing is normally earthed via the kettle lead plugged into it, but not sure if I should connect a direct earth to the casing, to be on the safe side?
I don't think the PSU would need an earth - should be earthed inside.
You normally bring the mains in (via kettle plug) to a panel, where it's switched, filtered (sometimes), fused and the earth brought out to a tap-off star point where all the other earths in the cab can connect to.
The PSU is fixed down to an MDF board, so the only earth it has is via the kettle lead. It'll be easy to fix an earth wire to the case, and I guess even if it's not needed, it can't hurt. Thanks all!
