PSU Voltages
dj_yt
787CR
Just bought a new PSU from arcade world. I wired it into my cab and measured the voltages at the PSU itself.
On the 5v rail, I'm getting almost exactly 5v
On the -5v rail, -3.80v
On the 12v rail, 9.89v
Am I missing something before I return the item, or should the -5v and 12v rails be close to spot on?
If I adjust the voltage adjuster dial, I end up with close to -5v and 12v, but the 5v is then way too high!!
Just to clarify, there was no load on the PSU when I took these readings. Would that present a problem?
dj_yt2015-12-08 23:18:21
2,265CR
Wouldn't worry about that, all sounds fine. You'll likely need to increase the +5 once there's a load on it, and when you do the other voltages will get closer to expected values.
dj_yt
787CR
Makes sense. I fitted this new PSU to run one of the Minikab PCs as it had 4 amps on the 12v rail. However, it doesn't seem capable of doing so. I will probably use an additional power supply instead and keep it for original PCBs
big10p
Coins detected in pocket!
6,085CR
This is why I have a couple of 5ohm resistors connected to +5v on my own MAME board. This puts a 2amp load on the +5v rail, which seems to enable the voltages to regulate nicely.
dj_yt
787CR
Interesting thanks for the picture.
I will try that in the medium term. I am a bit surprised this PSU doesn't work nicely even with the voltage turned up given its 4A on the 12v rail. The other lower power model I own for my test rig seems to be bang on 12v with no load.
I guess they are primarily designed to drive the 5v though. And if that is omitted will not behave correctly. dj_yt2015-12-09 08:26:28
big10p
6,085CR
I guess it just comes down to differences in the various makes/models of PSU. Yeah, they are usually designed to primarily drive +5v, though. I've seen ones that will auto shutdown if there's no load on +5v.
dj_yt
787CR
Hi big10p - just wanted to say thanks for your help and photo on this.
In the end I needed two changes:
1/ I connected a 10 ohm resistor to the PSU across the 5v rail. This, as expected, pulled up the 12v to the correct value.
2/ Even with the above. the 4A arcadeworld supply did not have enough juice to power the PC. I used an external 6A DC supply.
Everything is working great.
Next I need to make the setup a little less ghetto. Ideally, I need to mount the resistor on some kind of metal plate to dissipate the heat I think. Where did you get yours from?
big10p
6,085CR
Glad to be of some help.
I cut a length off an old copper ruler I had, to use as a heat sink. The pic I posted is actually an old one. I now have the resistors mounted at the back of the board on small, metal risers (still attached to the copper plate). Thought this would help dissipate the heat, as they get pretty hot. They have a pretty high temp rating, though - about 200 degrees, I think.
P.S. I have to power the PC with a separate 12v PSU, too. It's an i3 CPU, so the JAMMA PSU just can't supply the amperage. I needed to have the 12v rail regulated properly to power my separate sound amp, coin mech and marquee light.
big10p2015-12-13 12:01:40
