Rally X video problem.
Lurch666
21 (100%)
4,517CR
This Rally X is working but at first it was playing blind.
I had sync but no video. Found a bad LS74 at 7N which produces blanking signals and replacing that got video albeit messed up. The radar was incorrect colours and the main play area was all white.
Got the main playfield up by replacing the LS02 at 10L.
Some sprite issues have been solved by replacing some bad LS163 chips at 8J,9H,9F,10A,10H and 10F (Didn't replace them all but can't remember which ones I did replace and too lazy to go look).
Anyway there's a few little issues that I think is down to video ram but there is one big problem that I can't solve because I have not been able to figure out where on the PCB the radar screen is generated. Not the blips (which are sprites) but the info on the right of the rally X playfield.
Here is a picture of how it looks:
Text is missing and colours are incorrect.
Anyone know where this generated? The colours on the main playfield are correct but the radar and other info are wrong.
Also when the game is booting up the 'ROM OK' and white grid are not showing also most of the text on the player start screen and game over screens are missing.
They are there as my video probe can show them but they must be appearing as black on black.
Monstermug
1,807CR
what i usually do is remove eproms until the bit i want to find changes. then work the address lines until i find the faulty TTL that is responsible for it.
Lurch666
21 (100%)
4,517CR
Rally X only has one graphics eprom though.
I'm pretty sure it's something to do with the colours not the bitmaps since the graphics that do show are correct.
I'm looking for a missing bit in whatever part of the circuit handles the colours but no idea where to look as everywhere I've checked so far seems OK.
Monstermug
1,807CR
I only have a namco version so was probably no point in digging i5 out. Any chance you can tell us anything u learnt from this hardware? I find that kind of info much more useful than if symptom x then replace y kind of logs.
Lurch666
21 (100%)
4,517CR
I'm not that good. All I can do is find what chips are possibly bad and replace them.
Then if a board has a similar problem the area where the chip was replaced would be where to start to look.
