Rastan roms question
robotech
823CR
Hi
does anyone know if i can read the taito mask roms bo4-1to8 properly with my mini pro programmer
As the toshiba rom chips are not on the drop down list of selectable toshiba chips on my programmers menu
i can read them to see there is data on them and all looks good but when fed into rom ident it does not recognise what they are
Is there another compatable chip i can set the burner to
to read these properly im still learning so the differences between chips and numbering on them is baffeling me a bit
The board works fine apart from lines on some sprites
Which on another guys rastan repair log that had similar issues it was the taito roms at fault
thanks
robotech2020-02-26 22:53:32
Vamino
Insert coin(s)
2,700CR
I know I had to test quite a few different chips before I could read some from a couple of my boards. Not sure what the ones on rastan are mate.
Hopefully someone else can chime in and tell you what selection to use.
robotech
823CR
Yes mate i can read them sort of but i guess its not reading them properly
Maybe i need an older programmer
We had trouble trying to read some old game roms with that programmer before
I have the serial stack eprom burner too
But need to set up an old pc and find software to use it
Which proberbly wont happen tbh as i have no time or space really at the moment to go digging in the loft for an old pc or any space in the shed to set another one up
Vamino
Insert coin(s)
2,700CR
I'm surprised no one has answered your question mate, have you pissed everyone off or something?
Maybe you could try changing the subject title to something a bit more explanatory, simply putting 'Rastan' may be a bit too vague and the person who knows ythe answer has not read the post!
Just a suggestion mate.
robotech
823CR
Dont think i have done any thing to piss any one off
Tbh mate i only ever seem to do people favors
And have Only ever had one falling out on here when i got ripped off
Ill try changing the title see if any one is interested
Its not my board im looking at it as a favor for another member
Im not on here as much now as the forum seems a bit dead topic wise
Just the for sale section really that gets all the action
And im not buying anymore cabs
Vamino
Insert coin(s)
2,700CR
I'm just joking mate, I don't think you've pissed anyone off. You have done loads of favours for myself and others and I was just surprised no one has commented yet.
I've just checked Google and spotted these pages:
https://www.jammarcade.net/tatio-rastan-repair-log/
https://www.jammarcade.net/rastan-repair-log-2/
https://www.jammarcade.net/rastan-repair-log-3/
All Rastan repairs on Jammarcade website:
https://www.jammarcade.net/tag/rastan/
From repair 1:
'I checked all the ROMs that hold the background data and they all checked out fine. These are MASKROMs and can be read as either 27c301 or a couple of reads as 27c512 with a small modification.'
From repair 2:
I could replace this bad looking hacked EPROM with a blank TC531000,
LH531000 or a HN62331 mask ROM as they seems to have the exact same
specs and size than the original mask ROM but it seems nearly impossible
to find these chips nowadays.
Did you try reading them as the above chips mate?
robotech
823CR
Yes i skim read most of that repair log last weekend (maybe thats my problem :) )
And seen that the taito chips were unavaliable
And other chips could be modded to replace these chips with wire mods the bit in repair 2
Ill have a proper read again the weekend
But i wanted to find out if the actual chips it has now are any good i guess you could just order 8 chips mod them and burn mame images to them but its going to be quite expensive and time consuming
Or buy one chip and re burn it for each rom position and test
I think i was reading them as a 27c512
But they would not be recognised with rom ident
The other B04- roms at the bottom of the pcb they just look lie normal eeproms could be read that way but i still dont think correctly maybe i need a few more goes
Reading them with different settings on the programmer
Would be nice if someone with previous repair experiance
Gave me a bit of guidence i know there are some clever people on here
robotech2020-02-27 04:49:16
robotech
823CR
Pretty sure the modded chips on that log have more legs than the standard chips and overhang the sockets
robotech2020-02-27 04:50:21
caius
588CR
Rastan PCB uses 28 pin 1Mbit MASK ROMs to store graphics data.You can read these devices as 27C010 but you must use an adapter.I designed one time ago :
You can replace them with 1Mbit 32 pin non-JEDEC EPROM (like 27C1000, 27C100, 27C301) but you must tie the extra pins to VCC as well as tie pin 2 to GROUND as /OE.You can use also 32 pin JEDEC EPROMs (like 27C010) but you must swap pin 2 an 24 too.
Some time ago I designed an adapter to use TSSOP Fash ROM device in place of 28 pin MASK ROMs:
caius2020-02-27 18:42:20
robotech
823CR
So an adapter is needed to read these properly
Thanks for the responce and information on chip types caius just what i needed
robotech2020-02-27 19:24:52
caius
588CR
Well, you can also do in this way :
Put the chip in a 32 pin socket. Pull out pin 22 of ROM.Join Pin 22 of ROM to Pin 2 of socket and pin 28 of ROM to pin 32 of socket then read as 27C010.
