Hi guys,
I learned a couple interesting things getting RecalBox Jamma working nicely in a Sega New Astro city, thought I'd post a few details.
My new astro came from JCL in china. I recommend them- probably some of the finest customer service I've ever had, but that's a different subject honestly.
I had a few unexpected challenges getting RecalBox working inside a real CRT/Jamma box, plus a few things that were much easier than expected.
One thing I found after lots of searching.. the power supplies on sega candies usually need maintenance, and even after that they aren't reputed as super reliable. Mine was sending out 4.8 on the 5v rail.. I could adjust the screw with the tinest touch and it woudl jump to 5.2 or so. Getting this working happily with a Raspberry pi wanting to boot from cabinet power was interesting. Too low and you get a pop-up warning that takes forever to go away about undervoltage. Too high and you risk sending too much power to the Pi and or other components.
You can disable the overvolt cutoff on the recalbox board- it's just under the notch of the jamma connector as shown here. In my case, I managed to tweak to about 5.15v on boot, which dips to 5.0 under load. This satisfies the rasberry pi which seems not to mind the very short over-volt on boot-up.
Here's the little dip switch:
