Depends on the cab tbh. It's pretty easy to measure the depth. For info I made one once for an Atari cabaret cab and used 20mm chipboard and it fitted perfectly. Once painted black you couldn't tell the difference between it and a real one. When using chipboard it's a good idea to seal the edges with wood hardener so it doesn't flake away over time.
That's good advice on the wood hardener, I'll do that. Chipboard's ok then. I hadn't realised that there was variation in thickness, I'll get into the storage and measure up.
