Replacement CPS2 batteries help please
FanDabbyDozy
22 (100%)
170CR
Hi I recently purchased some Saft 1/2 AA batteries LS 14250 (these are to go in battery holders).
They were advertised as new stock with a ten year shelf life and that they would measure 3.67v
When I got them they measure 3.64v and the batteries I am talking out are at 3.66v-3.67v but are very old.
The date code / batch on these batteries is: 16210A294 to which I am guessing they were made in 2016, so not so bad, but worry on the voltage, or is this ok?
FanDabbyDozy
22 (100%)
170CR
Hi Mike thanks for the link, they test 36.4v when another battery (old one) tests 36.7v at same room temp.
Does the date code look like it will be 2016 to you?
Thanks Adam.
obcd
3,830CR
Maybe you can check the specification of the battery. There might be a tolerance upon the output voltage. 0.04V isn't that much. The datasheet might also give you information how you could figure out the date of manufacturing. If the battery is in a socket, it's not very hard to replace. I doubt anyone will take sold batteries back, as you could have drained them or mistreated them. There is no way to figure that out.
