Replacement Fluorescent Tubes
Outrun2
Colonel Outrun
1,181CR
I need to replace a marquee fluorescent tube - it's in a Sega initialD single cab so T12 40W 2ft. The ballast runs off 100V but does voltage matter in this case? I think a Naomi universal uses the same tubes/ballasts.
No chance of getting one locally so anyone have a good source for replacement fluorescent tubes?
Most tubes this size seem to be blacklight for insect traps, but this one looks ok..
https://www.easy-lightbulbs.com/light-bulbs/fluorescent-tubes/t12-fluorescent-tubes-38mm/2-pins-at-either-end/F40T12K-W-CA/
Any thoughts..?
obcd
3,830CR
We simply take an available tube that is the closest match to the tube that was in the cabinet and adjust the sockets (if needed) to the length of that tube which is usually just a couple of inches longer or shorter. Some cabinets like Naomi have the tube sockets unfixed. (The tube is fixed in two clips) That's the case where you don't have to adjust the sockets position. You can have problems finding a proper working starter. We usually don't replace the starter, as in our cases, the lamp is only started once in the morning and switched off at night. It's not like in normal use where it's turned on and off several times a day. You could also go for a led tl tube replacement, but I don't know if those work on 100V. They have a buildin switch mode power supply, so it's very well possible they do.
Outrun2
Colonel Outrun
1,181CR
Just for info and future reference, I ended up getting two tubes to try. The one I linked to originally and an 18W T8 as mentioned by Chrisgonz1. Both are fine in my initialD lightboxes and I would agree, the 18W is easily as bright as the 40W - possibly brighter as it's a 'daylight' tube.
This place was very good, packaged well and quick delivery..
https://www.easy-lightbulbs.com/light-bulbs/fluorescent-tubes/t12-fluorescent-tubes-38mm/2-pins-at-either-end/f40t12k-w-ca/
https://www.easy-lightbulbs.com/light-bulbs/fluorescent-tubes/t8-fluorescent-tubes-26mm/2-pins-at-either-end/f18t8-86-ph/
Bought both as I have a few cabs with these bulbs and it was free delivery over £10 - the T18 was about the same price as delivery so thought I might as well pay for another tube and get the free delivery!
