Replacement Joystick connection position
Copperband
72CR
This is probably a very stupid question…I am replacing the Sanwa 1p stick with 2P sticks on A Vewlix cab. The current Sanwa has a connector that is attacked to the Taito “s plate” and this currently sits at “6 o’clock”. The replacement sticks fit in a slightly different way, via the metal plate they come with, i.e. not the Taito S plate. They can only fit with the connector at 3 or 9 o’clock.
By doing so, my up, down, left and right will presumably be messed up.
Do I therefore need to unscrew the plastic part of the joystick from its metal plate and rotate 90 degrees?
Thanks in advance
thegreathopper
1,252CR
Thanks in advance
Yes that’s what I would do.
