RetroiPie
Hitesh
207CR
Got a Raspberry PI as a birthday birthday pressie.
I have formatted the card and installed Retropie Image using Win32 Disk Imager.
Nothing happening on PI when I insert card.
Just a red light.
What am I doing wrong
devtty0
222CR
is it connected to the TV?
also, are you using the right version for the type of PI? (there are three revisions of the raspberry pi, and you need to use the right OS version..)
JC_R4CER
126CR
You'll have to make sure the image you're using is compatible with the model Pi you have.
I'm currently building a Cupcade (Raspberry Pi mini arcade), but the image requires an old model B+ and nothing happened when the image was used on a new model Pi
G
Guests
Guest
I've seen this before and it's typically a case of incorrect file system on the card. Make sure the card is formatted in FAT32 and not NTSC/exFAT. If it's under 32GB in size this tool should work fine: https://www.sdcard.org/downloads/formatter_4/
If it is over 32GB you will need a partition manager to format the card properly in FAT32 (I've forgotten the name of a good one but google search will bring up plenty of options).
Also make sure it's a good brand SD card as retro pie can be picky when it comes to cards. If it's a cheap one from china don't even try...
Good luck
obcd
3,830CR
Win32 Disk Imager simply copies the image over to the sd card on a sector level. It doesn't matter how the card was formatted before. After the operation, the card will be correct as also it's master boot record and partition table are overwritten.
Some cardreaders can't be accessed properly on that level by programs like Disk Imager. Try it on a xp computer to make sure. I would expect the program to generate an error if that's the case.
Maybe you have bad luck and your pi is doa. Can you post a picture of your pi to confirm that it's really a pi2 or pi3. Have you checked the voltage of your power supply. Another thing you could try is another sd card. Not all are compatible. It's pretty much the advice you will get on the pi forum as well. Try exchanging everything non pi. If that doesn't work, it's maybe the pi at fault, but highly doubtfull....
Hitesh
207CR
Thanks to everyone who has helped.
Bought a Sandisk 16gb card and its has worked fine.
Looks like the memory card that came with the official Raspberry Pi Kit from Amazon is corrupt.
Now onto figuring our Wifi, Controllers, Roms...................
Hitesh
207CR
Next problem : Transferring Roms
Guides say that create a folder called retropie on a FAT32 USB stick and plug it into PI.
The software will create directories.
I have done above but no directories to be seen...
Mr20to5
1,366CR
Follow the youtube video I posted earlier. You need to load the file, then put it back into the rpi, then put it back onto the laptop.
Video shows you the guy doing it real time, step by step.
