Ringedge setting trouble
145CR
We know that he must have an RE1 as he has an Initial D8 cabinet.
The pink screen is 99% hit on the graphics card drivers being wrong, the system wouldn't display the colour pink for any other reason. If it was an official Ringwide SSD + chip placed into a Ringedge, it would come up with an ERROR in segaboot rather than just hanging to a pink screen. It looks like he's got an unpatched version of Sonic Racing meant for Ringwide, with Ringwide graphics drivers + card, or something else odd.
R.E the structure of the games. They are the same for Ringedge + Ringwide + Ringedge 2, all Windows Embedded images, with multiple partitions. One partition contains the Windows installation and drivers for the specific machine. A windows installation with Ringedge2 drivers would not work properly on a Ringedge 1, and a Ringwide installation with Ringwide drivers would not work on a Ringedge etc.
There are lots of different images floating around of games and multis, some are patched some are not. Images that work properly on their own respective SSD's don't work on some of the multi SSDs like Nikos multi, so it generally a bit hit or miss unless you know what you're doing.
Nikos multi is made for Ringedge 2, and I beleive can be found online. There is another multi in the guide below which is a patched version of Niko's multi for the Ringedge 1.
If he is a 'pc man' (love the term) then you can make your own SSD up. First get Sonic Racing from emuline (teknoparrot dump). Sonic Racing works straight off the bat when placed into a RE1 multi image - this is not the case however for most dumps for emuline.
You can then follow this guide on how to ATA lock/unlock a new SSD: https://github.com/ArcadeHustle/RingEdge_SSD_Softmod
This is a good guide explaining everything, with links to multi images (containing no games): https://github.com/ArcadeHustle/RingEdge_NoKey_softmod
I myself have pretty much all games running on a Multi on RE1 (even RE2 games, with 2GB of ram), with the exception of the IDs which run fine in their respective SSDs but seem to have a configuration issue when moved over to the multi.
"some ringwide games won’t run on re1, see Virtua tennis 4, monkey ball blitz, SRC etc"
I have all of the above games running on a RE1, so I'm not sure what trouble you're having. If you're using the teknoparrot dumps this could be why as they are heavily modified. SRC does have a slight graphics glitch caused by the fact it's not running on the Ringwide graphics card that I am yet to patch though, but for the most part if playable.
bobbydilley2020-07-05 12:08:00
AMS
66CR
Hehe this is what I meant but with fewer words
Well the discussion stated that games that work also in re1 work on re2
Well I can’t get sonic/Virtua tennis/ ko drive/src etc to work on re2
And showdown even needs 4GB I think
But anyway yes I think his hdd not the correct one with the right display drivers :))
madlok
22CR
Wow, that is a lot of replies, thank you.
I bought the game with key, but meanwhile I´m not sure if it really is original.
I am sorry I can´t give further informations, as I have no knowledge. I buy arcades and play them, had nothing to do with bootlag and so on until now.- But a Multi on my ringedge sounds great- can anyone tell me how I do it? It sucks to take out the re, open it and change game every time.
Update for my picture problem: I connceted another Monitor- good picture. So it IS just a Monitor setting problem. So:
When re boots up,it says "press enter for auto adjust" (or something similar) This could be it - Wich button is enter? Or do I have to connect a keyboard? Then- where do I connect it? The only USB is for I/O!?
Or does the Monuitor have switches for adjustment? There are some circuit boards on a panel which prefvent a clear view at the back of the monitor, and I don´t want to disassemble it all, when it is useless anyway. It´s the originalmonitor- does it have switsches for adjustment on the back?
Again- I have no knowledge- please be patient with me.I can disassemble and rebuild the arcades completly. But nowhere I find informations about settings or what the different circuit boards are good for (except I/O and Ringedge itself) so where should I get knowledge from?
Layer
376CR
The first thing you can do to check if it's an original is :
- to check if the game is rekeyed with another game key ; legitimate Sonic All-Stars dongle code is SBVH ;
- to check if your SSD is a TDK GBDisk RS2 (OEM Sega).
But these 2 steps are not sufficient to tell if the game has been patched to be played on RE1 mobo.
The final step would be to use Hdparm (or Victoria) to unlock SSD with TDK RS2 ATA key, and TrueCrypt (or BitLocker) to virtually mount it to be able to compare your game exe with the patched one available around the Web.
Layer2020-07-06 21:48:35
madlok
22CR
Hello again and thank you for the answers.
But please note that my priority is NOT if I have a copy or not for now.
My priority is how I can adjust my original monitor? When I connect another monitor, the picture is good- on my original monitor my picture is pink- thats definitly not a copy failure. I paid 100 for the game and the keys sell seperatly for 70-80 on ebay, so it´s ok for me, even if it would be a copy.
So- can anybody tell me how I can enter the auto adjust- does anybody have knowledge of the Arcade machine itself? Or do you all just have plans of making copies and such things?
(By the way-still would be glad, if someone could tellme, how I make such a "Multi" myself- or can offer 1...)
Layer
376CR
Hello,
Set all the dips in Off position, then switch on the game, it will start with an auto-adjusted resolution that fits with your screen.
Dip 7 On alone = 720p.
Dips 5, 6 and 7 On = 1080p.
madlok
22CR
Thank your for the tip with all dips off- didn´t know that. But it is not the resolution- it is the picture color.
I tried all dips off, hoping it would auto-adjust all- but no, still pink.
Do you know what Ringedge means with "press enter"? Do I have to connect a keyboard? Or is it 1 of the buttons atz the arcade?
I will post photos to visualize the problem.
