Screen issues post recap. Suggestions?
nam9
122CR
Ok, so after much ado and one brand new DMM later…
B+ measured 109.9v, adjusted to 118.1v.
15v on ZD measured 10.6v…
No appreciable difference to the display.
nam9
122CR
OK, so.. not the fastest progress, being mid summer etc.
I have focussed on the 15v test point, and interestingly enough.. it looks like this:
I'm no expert, but it looks a little toasty down there. Now, I have poked around with a multimeter - lots of readings not exactly to spec, but that R739 stood out.
In the schematics it is connected to ZD701 15v point. It is 33kohms in the same schematic, colour coded currently, but I am only reading ~3kohms resistance...
Going to take a slightly more structured approach to testing the passive components before I start pulling things. Progress??
Oh, and so far, all caps have check out... nothing in backwards!
nam9
122CR
Post holiday update.
Checked every capacitor for orientation, value and rating. All good.
Pulled 33k ohm resistor. Tested 33k out of circuit. Replaced.
Guess I will order up a LA7837 / LA7838 ic and see if i can replace that.
