Sega Naomi coin door
Markitanis
66CR
Hi guys got a Naomi and want to change the coin door. With mine the lock is in the centre. Where as the others I’ve seen the lock is to the left. Question is are they compatible with my cab
qjuk
50 (98%)
1,807CR
Are you on about the cash box door at the bottom of the machine? Sounds like you have got a “Securdoor” (ie., the whole door lifts away when you open it). You can change the door with a standard type. Just be aware though that coin and cash box doors do vary in size very slightly (even though they look identical). Usually it’s either a Mars or Coin Controls type (I think the Mars is very slightly bigger) and there are other types as well. Unless you have a selection of spare doors to try, it’s often easier to find one complete with the frame and replace both.
