Sega Rally 1 FFB error code
PhilT
154CR
Hi All
I recently got a Sega Rally 1 twin, one side has no forced feedback, I exposed the pcb's and the FFB board is flashing an Er 07 code, but its not one that listed in the manual so wondering if anyone knew what it meant.
My concern is that the board is really close to the rear base fan and that was totally fried, its a 240v ac fan that was not spinning at all but drawing power and getting seriously hot. Its been replaced now but I think its been bad for a while as the plastic parts of the fan were very brittle and fell apart.
Any advice gratefully received.
Phil
JESSYBR
163CR
i had that too with my rally
does it go left and right when you turn it on??
look at the potentio meters behind the steering
one off them id faulty
gr robert
PhilT
154CR
when the machine is turned on the ffb board starts 'counting' up and the steering moves a bit, eventually it displays the er07 code, the other machine does the same but quickly shows an 8c code.
Thanks for the tip I will check the pots and replace them.
obcd
3,830CR
The readout is the position of the steering wheel. Around 80 is center position. Around FF is fully clockwise and around 00 is fully counterclockwise (or the other way around) It's a hex readout.
PhilT
154CR
ah that makes sense. I guess it will change as the steering wheel is moved. Going to replace the pots and see what happens. thanks.
PhilT
154CR
So I pulled the back off and found the offending pot (top one goes to game board, bottom one goes to driver board) and to my surprise the lug wires were soldered onto it, I had expected it to be a detachable fitting. Is there some reason for this that I must solder the new pot in also.
Also the top pot works just fine but I am wondering if I should replace this one at the same time as its probably seen the same amount of usage as the bottom.
obcd
3,830CR
Normally, those pot's are pretty reliable.
If it would be a 2 hours dissasembly to get 2 that pot, I would say that you might replace the other one at the same time. It's not like your cabinet is still working many hours I assume, so I would stick with one pot. As a potmeter is an electronic component, soldering is the normal way to make connections to it.
PhilT
154CR
disassembly was actually pretty straightforward once I figured it out and got hold of the right tools...
I don't know why but I didn't originally get that a pot was a component!, but that makes complete sense once the obvious was pointed out to me. I will have to plead ignorance as its all pretty new to me and I am still figuring out how to use a multimeter...
My SR is still working for a living, its in my sons pub doing 12 hour days.
obcd
3,830CR
You can go to test mode and check the steering potmeter. If you turn the steering wheel slowly from left to right, it's readout should increase slowly as well. A bad potmeter can generate jumps in the number readout. Lubricating them with contact 60 is something that can extend it's lifetime. It's also important that they are mechanical properly aligned so that their resistance value increases from left to right. Some of them can be rotated 360 degrees, but others can only be rotated 270 degrees. Even if you can rotate it 360 degrees, it only gives you a normal readout over the same 270 degree angle, so you should only use it at that angle. Usually, dust is what causes them to fail.
PhilT
154CR
Resurrecting an old thread but when I started with this I could barely use a multi-meter so had no real chance of fixing it.
So just in case anyone else comes across this error, heres the problem and solution in my case.
Er07 means (I think) that the FFB calibration cannot be completed.
On start up the FFB board goes through a calibration phase where it spins the FFB motor and gradually applies the motor clutch until it detects steering wheel movement. So motor, clutch, steering wheel FFB pot and wiring all need to work so it can be completed.
In my case, the FFB motor was not spinning up. This was caused by faults on the FFB board itsself. There is a section of the board that controls the motor, this section had a blown large cap, a shorted triac and 3 open resisters.
I assume it got hit with a power surge or something but it now works fully.
ARWPP@
10CR
Hi
I have a sega rally ffb board that appears completely dead, the number indicator does not come on at all checked is gett +5V etc, any obvious next moves ?
is the Daytona board the same just different rom on it ?
PhilT
154CR
I had more problems with SR95 FFB. The usual suspect - Err 07. So just updating this thread with the latest findings in case it can help someone else at some point.
The FFB motor was spinning but the steering wheel did not move at all during the FFB board initialisation, it gave up and displayed Er07 after a short while. This indicated a motor clutch issue.
The clutch is applied via a 24v line controlled by the FFB board, during the FFB init phase, the count up on the FFB display is the amount of pressure being applied to the clutch. It gradually increases the pressure while trying to detect movement via the measurement pot. If it gets to maximum clutch pressure but has not detected any movement then it fails and shows Er07.
To resolve the problem:
detach the clutch supply wire and stuck 24v directly to it (blue wires) via a variable power supply, check the steering, confirmed clutch its applied to rule out the wiring and clutch mechanism.
detach the pot wires (striped wires, front of board) and measure while turning wheel, confirmed it was reading correctly.
So its a FFB fault. The 24v line is controlled by one of the pair of heat-sinked transistors. In this case it had shorted so no clutch was ever applied. I replace it and the steering wheel started to move but it only went half way though the init process before stopping again with an Err07.
After some head-scratching, I realised that while I had the dashboard out, the FFB measurement pot (the bottom one) had got moved a bit so its position when the steering wheel was centred read 7C on the FFB display. It seems that although the pot does not have to be perfectly centred, it does have to be within some tolerances, if its outside them, even if everything is otherwise working correctly, Er07 will appear. I realigned the pot so the steering centre position read 8A on the FFB display and now everything works fine again.
PhilT
154CR
There are 2 small upright headsinks with IC's bolted to them. Its one of them.
I just used a multi meter on diode setting and tested them both in circuit. One was shorted so I replaced it.
