SEGA System2 jumpers, purpose?
keropi
90CR
Hello!
anyone knows the purpose of these solder-jumper point on SEGA System2 boards?
I have an original Choplifter and a Wonderboy in Monster Land (cannot say for sure this is a conversion or not) and they have the jumper under IC75 different.
Now Monster Land works correctly with both settings but I am now wondering what the correct one is...
Any ideas? thanks in advance!!!
smarty
Ready Player One
1,305CR
My System2 Choplifter is patched the same as your two photos. The blue wire must be a factory mod as mine has it too. They might be marked up on the Choplifter schematics as they’re on the web if you want to search for them.
smarty2020-01-05 18:40:36
keropi
90CR
the blue wire is a factory mod so that you don't need a protection mcu for the games
this is weird because my original choplifter has the bridge on both points under IC75 ...
left of the "jamma" connector there is a silkscreen with the pcb part number, can you tell me smarty what your board has there?
keropi2019-05-17 10:40:05
keropi
90CR
thanks!!!
it seems you have another revision ...
my boards are 171-5303-01 (choplifter, both points soldered) and 171-5305 (same as your pics) and they don't use the protection MCU
atm I left the jumpers as they are , both boards run Monster Land just fine (after swapping ICs that is) and original Wonderboy... so maybe those jumpers are revision dependent and not roms used ... no idea :
anyways it seems this will remain a mystery - thanks though smarty for the time spent on this!!!
keropi2019-05-17 23:55:53
