Setting 5v Using LED Voltmeters
Flinnster
The Dino King
29 (100%)
2,566CR
What have you connected your switcher to? Incoming mains @ 240v?
Sounds very odd that what you are seeing is off the scale - they are normally pretty close from factory and tuning the dial will go either under 5v to around 4.3v or above to 5.8v or more.
Don't worry too much about 12v reading, it is usually more 'floaty' than the 5v anyway, so has a wilder variance.
-5v depends on what boards you have. Modern ones rarely use it. But if you are looking to run older games, you'll find the sound circuits won't work without -5v, or as mentioned above they won't even boot.
Flinnster2018-08-04 22:48:31
deanzor
139CR
In this instance, I'd chopped the end off a kettle lead and plugged it directly into the mains via an extension cord. I just wanted to test out my Mr Driller 2 board (and the video on a gutted DK monitor) to see if the signs were promising ahead of me putting it all together properly when my control panel arrives next week.
Not impossible that the multimeter isn't great - borrowed it off my dad and it's about 20 years old .
EDIT: Tested the voltage on a couple of new AA Duracell batteries. Both metered at 1.63v. Says 1.5v on the side of the battery - close enough?
deanzor2018-08-04 23:27:59
grobda
1,061CR
Just reread this thread and put a few updates on it. Thanks for everyone's input.
any inaccuracies or missing information please let me know.
mecha
10CR
I made this several years ago to aid in the testing/adjustment of power supplies.
http://www.arcaderepair.net/the-essential-psu-guide/
I had a Sega game a few weeks ago where I had to completely overhaul the power wiring in it because it was losing almost an entire volt. which is not normal. I think after replacing it all I got it down to like .15V or so. fork terminals on power wiring are getting cruddy now too (90s games are going to be 30 years old??) and will yield sharp drops.
I don't ever encourage stepping voltage up super high at the power supply to get it to somewhere close to where it should be at the board without addressing the mediums of power transfer first. (that sounds really complicated)
