[SOLVED] GORF Power Supply conversion help
RGP
Meeter & Greeter
2,039CR
Thanks for everyone's input so far on the GORF stuff, I thought i'd start a new thread for this as it's more specific.
A bit back I was investigating the control stick lights and rank lights on an upright:
http://www.ukvac.com/forum/gorf-rank-and-control-stick-lights_topic335203.html
On further investigation of the machine it's definitely that pin 17 isn't being fed anything because all the input pins responsible for it on J1 of the power board have been cut to bypass the power board.
So, i'm proposing to make my own adaptor for a switcher to finish the job for both me and Andy at the same time.
Here's the GORF power board schematic:
And here's my proposed pinout conversion:
As far as I can see, J1 isn't needed at all here, display lights I assume are the coin door lamps and are fed directly from the transformer anyway.
In Andy's cab on J1, only pins 8,12 (12v) and 10,11 (14.5v) are connected - the others are cut. 10,11 seems to feed the +12v line after the LM317 set to 12v and the other purpose it to power the RESET signal.
I know my drawing isn't ideal schematic standards, I wanted a pinout that showed 1-19 vertically on the right for wiring up.
+5 at pins 18,19 no problem, +12 at pins 7 and 8, no problem, -5 at pin 2 no problem and GND at 13,14,15 and 16 reading directly across the original.
I don't think the reset line is actually in use in this way and has been tied to +5 elsewhere as I can leave J1 entirely disconnected and the game will start.
I wanted confirmation on the V-IND/V-AUDIO stuff, best as I can see, the input at J1 goes through some diodes to become DC from AC off the transformer and is then just fed straight to the sound board +/- V.IND and +/- V.AUDIO.
Am I reading it right?
I've got some 0.156" headers to make the 19pin connector which i'll have to glue down to a stripboard and then i'll jumper wire them from a connector to the switcher as a prototype.
I intend to make this a single cable adaptor when proven.
Anyone got any thoughts on the above?
Update 03/Nov/2013
Thank you to everyone who contributed to this, especially chadsarcade for pulling his cab apart to verify my wiring plan - i've managed to convert U72's cab to work properly from an SMPSU and get the rank and stick lights working properly. Mine is next, however, on testing, the two spare boardsets (one Andy's, one mine) don't work
but i'll start a different thread about that.
A youtube video has been produced documenting it and also some gotcha's I discovered along the way.
Grab your popcorn and get comfy - it's a long one....
[tube]fIrne0YUhe8[/tube]
RGP2013-11-03 15:33:41
chadsarcade
Lord of Vectors (tm)
443CR
Ok here you go... overall cab shot:
Close up of the business end:
The wire colours are:
+5v Red
Gnd Black, Green
+12v Yellow, Blue, Orange
-5v White
I think I used different colours for some of the same values to differentiate out the roles.
So on the diagram above, from L to R (pins 19 to 1) -
19: +5v (red)
18: +5v (red)
17: +12v (orange)
16: n/c
15: Gnd (green)
14: Gnd (black)
13: Gnd (black)
12: n/c
11: Gnd (green)
10: n/c
09: Gnd (black)
08: n/c
07: +12v (yellow)
06: *key*
05: n/c
04: n/c
03: n/c
02: -5v (white)
01: +12v (blue)
Looks like I only connected wires to pins where there was a connection on the harness, hence I have a few n/c where you have a connection.
Hope this helps.
chadsarcade2013-09-30 18:35:30
Jase
294CR
Jesus. I've just been reminded that for all these years, I have been running my Gorf with a switcher connected to the molex plug by just shoving the wires into the molex!
  • Like
Reactions: trm
RGP
Meeter & Greeter
2,039CR
Thanks Chad, thats unbelievably helpful.
My reading of the original power schematic was right - J1 is unused with a switcher.
Your pin 4 (RESET) isn't attached, i've heard lots of different reports about this, i'll try without and with. I could always put a small switch in the line if needed.
I can see how pin 3 (+V.IND) gets 10v and (+V.AUDIO) gets 13 - 12v is passed through a diode which will lower the voltage via forward dropout to 11.3 anyway unloaded, add load to it, ~10v. The 13v rail is because they send it through an extra diode and then a capacitor across the AC so it will actually discharge more current into the circuit probably raising the overall voltage.
Whichever way, both are fine at 12v supply - if only I knew what V.IND was separately from V.AUDIO.
I think I have enough now to make an attempt, watch this space later.....
RGP
Meeter & Greeter
2,039CR
Don't suppose you can give me a hint on where you've pulled your 240v feed from, Andy's already has a feed but mine doesn't.
Be nice not to molest the loom.
chadsarcade
443CR
Now you're testing my memory! I think the mains L and N is pinned down under a couple of (uninsulated!) hex head screws on the wooden block which the transformers are attached to. These screws act as jump points, and pin down a few different feeds to the various components and fittings. The wires have eyelets on the end and are just secured down and connected together via the screws. I just added a couple more at these points (plus Earth which is usually found connected to the body of the transformers via one of the screws mounting them to the base board).
At least I *think* that's how I did it from memory, I'd have to pull the cab out again to check (though I've a recollection of accidentally touching one of said uninsulated screws with a screwdriver to another uninsulated point and tripping the mains
Failing that, the easiest way would probably be to add an extra set of L and N wires from the input tags of one of the transformers, and grab earth from the mounting point of one which is earthed as described above.
Hope this makes sense.
Oh, and thanks for the comments, guys!
chadsarcade2013-10-01 09:48:54
RGP
Meeter & Greeter
2,039CR
A (semi)successful end to the tale...... Top post has been updated with details - thank you everyone.
As it turns out, i'm lucky and have a multi-input primary power transformer in mine and so did Andy, however, I discovered the SMPSU voltage had been machete'd into the monitor power but still, at least the tabs had been moved to make it 240v input.
To any new players, most SMPSU's can run off either 110v or 240v AC. In the GORF power arrangement, input voltage goes through safety switches to the primary transformer and then to a secondary 1:1 isolation transformer (output voltage same as input voltage but just isolated electrically). If you left the tabs on the 110v input and fed it 240v then you'd still blow up the monitor because the primary transformer would be only stepping down the 240v by a very small amount - maybe 20v and the secondary is 1:1 so it would output the same as input so your monitor would be fed around 220v which it may or may not blow the power section - but very likely wouldn't start up.
By moving the input tabs from the power cord to the 240v position the transformer has an approximate 2:1 ratio so 240v in = 120v out which is then passed to the secondary transformer and which isolates it from general mains and feeds it to the monitor, the Electrohome G07 wants 120v input so its quite happy.
The SMPSU was tapped into the 120v line and set to 120v input so was working fine.
In general, convert your cabs to 220/240v for UK/Europe as the SMPSU is likely calibrated for the 50hz frequency whereas the USA uses 110v at 60hz so the SMPSU could potentially be working a bit harder to produce the same results - without investigating i'm not sure but just beware of it.
RGP2013-11-03 15:43:14
andrew96
899CR
smps doesn't matter if its 50 or 60hz, it rectifies the AC to DC then chops it up, so this bit sees DC. So the only important thing here is to make sure the switcher when set to 120v input is not then presented with 240v! make sure its marked up well its set to 120v, then if you ever remove it your know rather than a big bang when it gets put onto 240v!!
  • Like
Reactions: RGP
RGP
Meeter & Greeter
2,039CR
Thanks Andrew, never been 100% on how SMPSUs coped with difference in frequency but that means the input stage of the circuit must be the same as we see on linears with the bridge rectifier / smoothing cap arrangement.
Any really good writeups/tutorials out there on how switchmodes work.
